Results 1 to 15 of 15
Thread: Atfer fast 92/92 install
03-15-2010, 05:12 AM #1
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
Hey guys I installed the fast 92/92 combo on the car yesterday. Everything seemed fine but now the trans is acting up like crazy when I stand on it the car will stay in gear or upshift????? If i manaully downshift it works great and hauls anyone heard of this bullshit before?
03-15-2010, 06:09 AM #2
- Apr 2008
- Madison, WI
The only thing that comes to mind is that GM service bulletin about overly-oiled K&N air filters where the oil transfers onto the MAF sensor wires and throws off the grams per second reading. Thats been known to cause transmission shift concerns. Anything like that ring a bell?
03-15-2010, 06:24 AM #3
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
It would if I used a k&n filter but i dont... I didn't have my egr block off plate at the time so i just disconnected the sensors and the tubes just bend out of the way. I have to put the block off plate on tonight or tomorrow you think that may have anything to do with it? I know all this computer bs one things not hooked up the whole thing could be jazzed up
03-15-2010, 06:33 AM #4
- Apr 2008
- Madison, WI
yeah if you have an open EGR port on the exhaust manifold/header then thats a major exhaust leak that could be throwing off the O2 sensor readings and might be causing some other problems
03-15-2010, 07:00 AM #5
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
Yeah I'm putting on the egr block off plate on asap. The odd thing about it is when i manually downshift it, It flys big difference from before i'm just upset because my corsa install was fucked up as well and $2400 later my exhaust is chatting and the tranny is acting up.
03-15-2010, 07:26 AM #6
- Nov 1999
- over here...
are you running with the egr open??? did you get tuned after all the installs???
03-15-2010, 07:52 AM #7
- Jan 2006
- Shepherd, Michigan
well i think we figured out what the problem was.
egr needs to removed or closed.
03-15-2010, 08:42 AM #8
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
Yeah the intake mani is closed/ sealed however the egr tube is just disconnected sensors removed etc. i didn't have the egr blockoff plate with me at the time so i'm going to put that on asap. I wouldn't see how that would effect the trans? I havn't had it tuned yet i have a april 9th appointment though. I gotta put on the electroic water pump still.
03-15-2010, 08:52 AM #9
03-15-2010, 09:49 AM #10
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
I had the o2's deleted in my computer as well as torque management but i can see how the computer would be all over the map.
03-15-2010, 03:21 PM #11
you didn't get ALL of the o2's deleted you only got the rear ones removed.
03-15-2010, 04:06 PM #12
03-16-2010, 09:45 AM #13
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
I only got the rears done. Yep that must be the problem thanks so much guys
I'm such a noob lol
03-16-2010, 09:54 AM #14
- Mar 2007
- NC
NBM- 1998Z28
If I remember right one of the wires that is in the EGR harness goes back to the O2 sensors. I would make sure that the EGR harness is unplugged and none of the wires is touching the motor. I taped mine up and stuck them out of the way.
TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
03-16-2010, 10:03 AM #15
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
FAST EZ-EFI System Install - EZ-EFI
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 08-02-2012, 11:39 AM -
FAST install/questions...
By RedHot99T/A in forum Firebird / WS6Replies: 10Last Post: 09-11-2011, 12:18 PM -
fast 92/92 install help
By johnny89345 in forum General HelpReplies: 5Last Post: 08-17-2011, 08:36 PM -
Question: Install FAST tb/intake?
By RoadWrath04 in forum GTOReplies: 2Last Post: 04-13-2010, 02:15 PM -
Fast install
By Camaroride32 in forum External EngineReplies: 2Last Post: 03-14-2008, 05:03 PM
