    Junior Member lookngoodSS's Avatar
    Oct 2009
    dayton
    02 SS camaro
    96 civic not engaging?
    my 96 civic's clutch went out so we replaced the following.
    Clutch plate.
    Pressure plate.
    Fly wheel.
    Master slave cylinder.
    But when i put the car in gear it still refuses to go. The mph will shoot up a little bit. But there is no movement. You guys are the smartest people i know.
    Any help?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Check your shift linkage.
    Perhaps when you put everything back together the shifter linkage is not set up correctly.
    1998 Trans Am WS6 SGM
    Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
    Alabama Member bamaz28's Avatar
    Jan 2008
    heart of dixie
    06 Jeep Grand Cherokee.
    02 superchipsZ28 M6(sold)
    replace throw-out bearing as well
    Member NaviDyn's Avatar
    Dec 2008
    St Louis
    Tan
    2002 GMC Yukon
    All I can think of is it wasn't put together quite right, and that is why the pressure plate isn't engaging. The linkage is a good place to check as suggested. But if you are moving just a little, then you should be in gear.
    Indianapolis
    2000 WS6 6spd Hooker LT
    How does the clutch pedal feel now? Normal? Or does it feel like it's just kinda there. You can push the clutch pedal down, put the stick in gear (that feels normal also?), let the clutch out and nothing happens? When you say the speedo moves a little, do you mean it is saying you are going (whatever MPH) but there is no car movement? Are the axles back in the transmission all the way? If the axles were out some, the speedo would show MPH but you may hear a grinding noise or maybe a faint noise. Sometimes if the transmission is in neutral and you rev the engine, the speedo will show a few, false MPH. If all the above check out, and the car worked ok before the clutch job, then you either have the wrong clutch/flywheel/throwout bearing/slave cylinder assembly, or it is put together wrong. If the clutch pedal doesn't feel normal, it's either air in the clutch hydraulics or a mis-adjustment somewhere, or wrong parts. Good Luck!
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    Quote Originally Posted by lookngoodSS View Post
    Clutch plate.
    Pressure plate.
    Fly wheel.
    Any help?
    sounds like your vtec went out....probly should add a turbo or switch it with a jdm sr22008y454y89 engine lol....im just kiddin man...hey i had to get in the honda joke before someone else did.
    Oct 2009
    dayton
    02 SS camaro
    turns out on stupid imports, the stupid axle wasnt in the trans the whole way... thnks for trying.
    Indianapolis
    Woo-hoo, I nailed it in post number 5. Glad it was just an axle not all the way in, and not a head-scratcher where you had to take it all apart to check for correct parts.
  1. starter not engaging
    By NVRANUF in forum General Help
    Last Post: 05-05-2016, 06:51 PM
  2. Tick MC installed, clutch is engaging at the top now.
    By Kramsdell in forum Manual Transmission
    Last Post: 11-22-2011, 08:29 AM
  3. Alpine Honda Civic Si - Civic Demonstration
    By Ed Blown Vert in forum Stereo and Electronics
    Last Post: 07-04-2007, 04:10 AM
  4. Difficulty Engaging Gears
    By qrunchi in forum Manual Transmission
    Last Post: 11-24-2006, 12:04 PM
  5. Clutch not engaging at all?!
    By Blkls1 in forum Manual Transmission
    Last Post: 05-19-2006, 04:11 PM
