Results 1 to 13 of 13
    Hamburg, Germany
    1998 Camaro Z28 A4
    sticky accelerator pedal
    my accelerator pedal starts feeling "sticky" after i drive a while, it works, but i have to push a bit more to move it. it returns to idle with no noticeable delay, only when i start from a stop, or when i held it in one position and then accelerate, it feels like it's stuck and then "breaks free".
    dry cable maybe? any other ideas?
    Member importhater81's Avatar
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Try cleaning the throttle body ,the blade made be sticking due to carbon build-up
    Hamburg, Germany
    1998 Camaro Z28 A4
    i'll try that, thanks!
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    When mine stuck I cleaned out the TB and I put a small dab of WD-40 on the cable.
    Tulsa,OK
    Quick Silver
    2002 Z06
    Yeah I think a gumed up TB will be the cause.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Hamburg, Germany
    1998 Camaro Z28 A4
    sounds like i got a project for next weekend or so... do i need to pull out the tb, or just clean it from the front opening?
    Oct 2009
    chicagoland,Il
    02 ss camaro
    don't have to take the tb off.get a rag and some carb cleaner,hold it open and clean it from the front...should take you about ten minutes...all you have to do is remove the bellows between the air lid and tb.
    Hamburg, Germany
    1998 Camaro Z28 A4
    sounds easy enough!
    Tulsa,OK
    Quick Silver
    2002 Z06
    Yeah pretty easy. If you have the time, taking it off and giving it a REAL good cleaning will not hurt.
    Hamburg, Germany
    1998 Camaro Z28 A4
    no more jumpy takeoffs!
    i just cleaned the throttle body, lot's of black gunk around the rim of the blade. didn't have the time to take the whole thing apart, so i just pulled off the bellow and cleaned it from the front with multi-purpose cleaner. did not spray anything in there directly, of course. but i got it pretty clean, and the accelerator feels nice and smooth again. thanks for the input everyone!
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    at least you dont have a toyota
    Hamburg, Germany
    1998 Camaro Z28 A4
    ... though we had a toyota yaris as a rental three weeks ago, and it was really nice for a small car. and we survived!
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    hahaha
  1. Help: Sticky Pedal/TB, only when runing
    By Vertiviper in forum Firebird / WS6
    Last Post: 06-01-2010, 06:00 AM
  2. Sticky clutch pedal? Makes car stall...
    By AKIRA in forum Manual Transmission
    Last Post: 03-03-2008, 12:38 PM
  3. Clutch pedal sticky? Car stalls..
    Last Post: 02-17-2008, 06:09 AM
  4. Accelerator assembly and Gauges
    By Banshee1967 in forum Parts For Sale / Trade
    Last Post: 08-09-2006, 09:26 AM
