Results 1 to 20 of 29
    Denver, NC
    Power steering fluid cooler
    Hey guys,
    Is there any real need for the power steering cooler on 2000 LS1?
    Or can i bypass it?
    Thanks
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    You can bypass it.
    old timer blue02Z's Avatar
    2002 Z28
    why do you want to bypass it?
    Member 99'CajunFirehawk157's Avatar
    39466 USA
    Bright Red
    99 Firehawk #157 Roadster
    Want to donate that cooler when you take it off, or Sell it to me?
    Regards,
    Todd
    #cajunhotrodder on instagram
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    PS cooler was added for the cars with 17'' rims
    Member devil6rr's Avatar
    NJ
    SOM / NBM
    2002 Pro Z28/2001 TurboTA
    +1 i can use a cooler to!
    Aug 2000
    Indy
    Quote Originally Posted by DIRTY JERZY View Post
    Negative red leader, stock on my 02 Z/28
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    39466 USA
    Bright Red
    IMHO: its actually not a cooler per say, I think its more of a heater for colder climates, actually if you think about it, the fluid in the radiator is hotter than the ps fluid so....???
    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    what , this thing?? not my car , file photo.... ....... I'm pretty sure they were gone by 01 as my 01 z28 doesn't have one and i got my car new from the dealer with 3 miles on it. they rupture on occasion and contaminate the coolant with PS fluid and visa-versa. so probably not worth the trouble
    Madison, WI
    2001 Silverado Z71
    F-body power steering cooler was standard on WS6 and SS models and it was an option to other V8 models.
    If anyone does replace their P/S cooler -- let us know if you find a one piece hose that fits, in lieu of fabbing up a piece of tubing between the existing hoses.
    Madison, WI
    2001 Silverado Z71
    Jeff are you talking about the rad hose or the p/steering hose?
    The radiator hose. If our cooler ever goes bad and I need to swap a hose in its place, it'd be nice to know ahead of time what works.
    Madison, WI
    2001 Silverado Z71
    Talking
    Jeff, I know its early in the morning...but don't you think a rad hose for a car without power steering cooler is one piece and will fit.
    I was up at 4:25 a.m. to drop the wife off for her weekend bus trip... didn't think this one through. I'll go back to bed now...
    Tulsa,OK
    Quick Silver
    2002 Z06
    LOL... I was reading through the thread hoping you would end up saying that
    No reason to keep the PS cooler if you don't want it.
    I imagine the power steering fluid gets quite hot. I don't think its there to heat up the fluid, that would make no sense at all IMHO.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Arizona
    The PS fluid gets hot from the pump itself, not the cooler. They can actually reach a boil and cause a sticking steering wheel when too hot in road course situations.
    The cooler will help with that to some extent. It can do an even better job if you run a cooler thermostat and reprogram the fans.
    Antifreeze at 180 is much cooler than 230, which does more than just cool the motor, it also helps an auto trans as well as a power steering cooler in this case.
    Member 666ws6's Avatar
    Greenville, SC
    2000 Trans Am Ws6 #2946
    I order a set of radiator hoses from Samco and they stated the set is designed to fit without the cooler, but can be cut/modded to fit a cooler. So I debated removing the cooler, but now I think I will keep mine due to what fbjones said.
    2000 WS6 TA #2946 - A4, Best 1/4: 12.5s @111mph.
    SLP LTs, 228r Cam, SY 3500, Shift kit, LS6 intake, underdrive pulleys, lid, p&p TB, Borla w/ cutout, Pro-kit springs, poly all around, Hotchkis suspension, 3.90 gears, tuned.
    So, why were they stock on the WS6/SS and only optional on other V8s?
    Madison, WI
    2001 Silverado Z71
    I think its a handling upgrade. If your auto cross racing, you're really gonna heat up the fluid.
  1. Do you run a Power Steering cooler?
    By b.lee in forum External Engine
    Last Post: 12-07-2020, 02:55 PM
  2. Looking for Power Steering Oil Cooler
    By NOS99HAWK in forum Parts Wanted / Trade
    Last Post: 07-02-2009, 04:18 AM
  3. Power Steering Cooler
    By Blackout01 in forum General Help
    Last Post: 08-03-2007, 09:54 AM
  4. Power Steering Cooler?????
    By VetNutJim in forum Camaro / SS
    Last Post: 01-06-2007, 08:18 PM
  5. power steering cooler
    By bevenue in forum Camaro / SS
    Last Post: 09-28-2006, 06:27 PM
