Thread: Starting issues
    so windsor ct.
    98 camaro ss
    Starting issues
    HEY,GUYS NEW TO THE SIGHT AND MY 98 CAMARO SS.I,M HAVING A STARTING ISSUE I HOPE YOU CAN HELP ME WITH.WHEN I TRY TO START THE CAR IT WILL TURN OVER BUT NOT FIRE.THE SECURITY LIGHT WILL GO OUT BUT CHECK ENGINE LIGHT STAYS ON.EVENTUALLY THE CAR WILL START AFTER MANY TRIES.AT THAT POINT A CAN SHUT THE CAR OFF AND START IT RIGHT BACK UP.NOT SURE IF ITS THE CHIPS IN THE KEYS OR THE LOCK CYLINDER ITSELF.THANKS FOR ANY HELP.
    Member Blue_01_Z28's Avatar
    Midland, TX
    Metallic Blue
    2001 Chevrolet Camaro Z28
    My LT1 used to do that but my security light would stay on, i'm not to sure about what yours is doind but, i would have someone check if there is spark. Or maybe if it sits long enough your fuel is falling all the way back to the tank and it takes it a bit to get it back up.
    Fuel pump on the fritz?
    Check plugs and wires.
    Member jb3golf's Avatar
    Zona
    1998 Camaro Z28 Conv. M6
    Are you getting any codes???? If so perhaps your VAT's system needs to be reset........You also may have a FUEL clog....in this case as you start the vehicle in neutral press all the way down on your gas to unclog the system at first, then let off it quickly. This happened to me and my car has been fine ever since. Let us know.....
  1. Help: Having issues with the car starting!
    By SOM2002SS in forum General Help
    Last Post: 04-01-2012, 06:32 AM
  2. Question: Starting Issues
    By afoster52 in forum General Help
    Last Post: 06-16-2009, 12:16 PM
  3. Starting Issues
    By BLUSTREAK in forum General Help
    Last Post: 05-16-2007, 08:58 AM
  4. Starting issues
    By knewsock in forum General Help
    Last Post: 05-17-2006, 11:04 PM
  5. Starting Issues
    By gnomee in forum LT1
    Last Post: 02-13-2006, 04:54 PM
