Results 1 to 16 of 16
    Junior Member orange T/A's Avatar
    Jul 2009
    Nebraska
    Orange
    01 Trams Am
    is it possible to pull a F-body motor from the top
    is it possible to pull a 02 trans am motor out the the top, or do you have to pull it out the bottom with the front suspension.
    You can, but out the bottom is probably far less aggravating. Those that have done it will post up their experiences.
    Bragg NC
    Met. Sunset Orange
    01 SS
    You can pull it from the top, i have done it twice, it takes a little bit more work but not too bad...
    J
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    With a couple of exceptions (and those were because they were doing an aftermarket tubular sub-frame), every one I know pulls them out from the top.
    Member squirlnutz's Avatar
    oklahoma
    2000 trans am
    Quote Originally Posted by orange T/A View Post
    it is possible and not to hard.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    If all you're looking to remove is the motor - out the top is the way to go. As said, it's not too hard.
    Besides, it's tough to find someone to catch it when you drop it out the bottom....
    Member jb3golf's Avatar
    Zona
    1998 Camaro Z28 Conv. M6
    What are your plans with the engine???? Whats your reason for wanting to do this???? Is it to install a cam/heads combo or something internal?
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    TPIS "Happy Hooker" is your friend!
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    Jul 2009
    Nebraska
    Orange
    01 Trams Am
    Motor needs new rings and bore out, burns oil pretty good. still runs good but, just doesn't like all the smoke.
    Pittsburgh
    2008 Hummer H3
    Question
    Question; how do you know it's the rings and not just valve seals?
    Jul 2009
    Nebraska
    Orange
    01 Trams Am
    I don't just a guess. Is there anyway to tell w/out pulling the heads?
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Pull the valve springs (nut shell) and pick up a set of new seals. Much less work and if that is'nt the problem your not out all that time and labor of pulling your motor only to find crosshatching still in your bores.. There's a fitting you can buy to pump compressed air into your cyliders to hold the valves up while you work on your seals. Just have to turn the motor manually to close each set of valves, working on one cylinder @ a time..
    Jul 2009
    Nebraska
    Orange
    01 Trams Am
    I will have to look in to that
    Pittsburgh
    2008 Hummer H3
    Wink
    Could save a lot of hastle and $$$..
    Zona
    Yep!! There is NO reason to even THINK about pulling your engine for a reason you can't confirm prior to.........Do as the guys above suggested, safe yourself a HEADACHE!
    Compression test. Test the cylinder dry and then with a small squirt of oil. If there is a considerable increase in compression then it is a ring sealing issue. If not, it is either the valves or valve seals.
  1. Question: Motor pull
    By Butch2000 in forum General Help
    Last Post: 03-18-2010, 06:18 AM
  2. H/C/I Swap...pull motor or leave it?
    By ls1camino in forum Internal Engine
    Last Post: 03-27-2009, 08:04 PM
  3. removing motor from the top of f body
    By BIG C in forum Internal Engine
    Last Post: 03-10-2008, 09:16 PM
  4. highest horsepower LSX engine? video of 930 hp pull all motor
    By powerjon in forum Multimedia Section
    Last Post: 07-03-2007, 05:11 PM
  5. Pull the motor without lift?
    By AirMarcus in forum General Help
    Last Post: 01-19-2007, 07:03 PM
