    1998 Camaro SS
    weird steering problems......solutions?
    ok, the ss has been having some rly weird steering problems. i have subframe connectors and a strut tower brace installed. i had to put a new tie rod end on last summer so i still have to get it aligned but whats weird is that the steering wheel just started shaking back in forth while i drive and sometimes the car drifts to the right and sometimes it drifts to the left. im thinking theres something else wrong with it other than just needing aligned. i know nothing about steering compononents really so any help is great. Thanks
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    it sounds normal to me for a car needing an alignment personally..i would get an alignment first and see if it fixes the problem before we even address a "possible" problem
    Nov 2009
    Norfolk, Nebraska
    2002 Camaro Z28
    Sounds like a bad tire. At what speeds does it start?
    Pittsburgh
    2008 Hummer H3
    Rotate your tires see if it goes away. If it does then I'd say bad tire. Usually it's wise to replace tierod ends in pairs of 2, for best results replacing them all is proper imho but I know not eveyone has the cash to do so.. Usually when a tire wears from poor alignment the effected tire/s will still continue to wear unevenly even WITH an alignment.
    Just tossing this out there.....wheel bearings? I had one go out on a DD long time ago and it shook the hell out of my steering wheel.
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Yes, this too..
    Member jb3golf's Avatar
    Zona
    1998 Camaro Z28 Conv. M6
    Quote Originally Posted by jmatt07 View Post
    OK EASY FIX HERE: YOU NEED AN ALIGNMENT ASAP!!!! Have you gotten one yet??? If not your totally WEARING OUT your tires!!!!! Your symptoms are EXACTLY what my car did after I installed new tie rods, rotors and sway bar......as soon as I got an alignment, it drove like a dream. DO IT ASAP......
    Zona
    I'm willing to bet your computer angle numbers will be WAY OFF!! Mine weren't even within the applicable range..........
    Member importhater81's Avatar
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Sounds like a belt separation in one of the front tires....rotate to the back and if it goes away replace suspect tire asap....Alignment issues don't go back and forth between pulling to one side then the other
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    The wandering could be a toe issue requiring an alignment. Shaking could be from a shifted belt on a tire or out of balance tires.
    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    i was wearing my left front tire pretty bad and the car was hopping in reverse when the wheel was full cut to the left. wandering on the groves bad too . i thought it was a bad tie rod end but 4 new skins.. and an alignment cleared it up. alignment guy said a lot of tow in the front left
    North Jersey
    2004 GTO M6
    Yup. Too much positive/negative toe will cause wandering and irregular tire wear. When I aligned my car, the computer read -0.15 on the left front and the right front was spot-on. The steering wheel was at 10 and 4 when driven straight, but if the wheel was completely at 9 and 3 the car wanted to pull right. After the alignment all is good.
  1. weird electrical problems??
    By wsickk in forum Stereo and Electronics
    Last Post: 09-09-2010, 07:12 PM
  2. Common Code List - Problems and Solutions Here
    By Hi-Po in forum General Help
    Last Post: 01-26-2010, 09:12 AM
  3. weird power steering fluid leak...
    By Spaz in forum General Help
    Last Post: 07-02-2009, 01:24 AM
  4. Weird feeling in my steering
    By ichliebecamaro in forum General Help
    Last Post: 01-10-2008, 08:11 AM
  5. 3 Problems........3 Solutions.
    By FSANE in forum Almost Anything Goes
    Last Post: 01-30-2007, 08:18 PM
