Results 1 to 10 of 10
    mercersburg pa
    hugger orange
    2004
    ABS light and display
    On my 04 GTO I deleted the ABS and went manual brakes. It works great, but does anyone know how to trick/ turn off the ABS light and ABS inop indicator in the center display?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Subscribed. I thought the only way was to physically remove the bulb. On pre 98 Camaro's you can ground certain pins on the PCM to shut off the ABS light, but I don't think that applies here with your newer goat.
    mercersburg pa
    hugger orange
    2004
    I'm sure its a quick easy fix by like you said, just grounding a wire or a resistor, just not sure which wire/wires lol
    I'm sure someone has done this before
    Member The Silver Goat's Avatar
    Dearborn Michigan
    Qucik Silver Metalic
    2004 GTO - M6
    How'd you delete the ABS??? I can't stand ABS with with an M6...
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by The Silver Goat View Post
    I went with a Wilwood mastercylinder, made a bracket that bolts in where the booster went to bolt the mastercylinder, then ran all new lines to the front and ran a line to an adjustable porportioning valve to the rear
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Now I am wondering if your lights can be tuned out with HPTuners or other software?
    mercersburg pa
    hugger orange
    2004
    My1stgto said they used ls1 edit to take care of his...but I've looked all through hptuners and it doesn't have bcm controls in it
    North Jersey
    2004 GTO M6
    Then try the LS1Edit and keep us posted.
    mercersburg pa
    hugger orange
    2004
    Lol I'm not made of momey and can go out and buy all the tuning software....lol
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    ^This. I'm thinking HPTuners (or the like) may be able to deal with this, i.e., you gotta turn it off.
  1. Heads up Display
    By 99WS6MAN in forum Stereo and Electronics
    Last Post: 01-30-2012, 08:11 PM
  2. any one here done a heads up display???
    By Spaz in forum Firebird / WS6
    Last Post: 03-15-2011, 06:15 PM
  3. what is this display screen for??
    By formula ws6 in forum Firebird / WS6
    Last Post: 07-30-2010, 08:12 PM
  4. Monsoon Display only on with ign in acc
    By Alex212 in forum Stereo and Electronics
    Last Post: 07-04-2008, 03:11 AM
  5. Head-Up Display (HUD) ??
    By Pewter WS-6 in forum Firebird / WS6
    Last Post: 01-10-2008, 01:19 PM
