Results 1 to 14 of 14
    Junior Member kevk77's Avatar
    texas
    2002 camaro z28
    gear oil question
    I screwed up today. To make a long story short I meant to grab two bottles of 75w-90 at oreilly and I guess I grabbed 1 bottle of 75-140 on accident. So I have half 75-140 and half 75-90. I didn't realize it till I had 2/3 of the bottle poured in. I know I should drain it but at 20.0 a bottle and a messy job I was wondering what yall thought If I just ran it.
    Member jerri311's Avatar
    Jul 2009
    Houston
    2002 Trans Am WS6
    I think you will be fine.
    Jul 2009
    Houston
    2002 Trans Am WS6
    Unless you want to spend another $50 doing it right away.
    Member Lawnboy's Avatar
    NY
    01 SS Built LS6 740RWHP
    your fine! i ran lucas oil additave and lucas rear end gear oil
    texas
    2002 camaro z28
    thanks
    I just went ahead and changed it again with the right stuff. Im sure it would have been fine but it kept bothering me.
    NY
    I am the same way , my TA cover was dripping a bit, i could wait to redue it
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Better to spend a little more $ and have peace of mind. I don't think it would've hurt anything but mixing oils can be a tricky thing. Sometimes they do strange things...
    NY
    I use Lucas, if it keeps tractor pullers rears together that have 3,000 hp , it will work fine in my 740 hp street car
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I use 85-140 dino oil in my rearend, the thicker oil will help disapate the heat better than the 75-90.
    SteveC
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    I have a buddy in my differential class who used dino based instead of synthetic like the manufacturer said. It was real cool taking apart that rear end and looking at the carnage it did all over the bearings and races.
    Good practice to do it right the first time and not the second time
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up
    I have been running dino oil in my differential for 9 1/2 years, and I have absolutly (sp) no issues whatsoever.
    SteveC
    Senior Member
    texas
    2000 formula
    i think originally GM used the 85-140........then changed it to 75-90.....no biggy as far as i know
    Bay Area
    my highbeams
    Quote Originally Posted by SteveC View Post
    SteveC
    My friend has a f-150 so his tolerances are different then ours( my point was simply my friend did not follow manufacturer spec). I should have taken a pic, oh the carnage!
    Member Blue Thunder 42's Avatar
    Crownsville MD
    98 SS Camaro
    You would have been fine most likely, a little mpg drop and 1hp loss. I wonder if it would run cooler like "SteveC" said?
  1. 3.73 gear question
    By Justin23454 in forum Drivetrain
    Last Post: 03-14-2008, 11:21 AM
  2. 3.73 gear question
    By therobman in forum Firebird / WS6
    Last Post: 12-20-2006, 11:41 AM
  3. Gear Question
    By rbrack in forum Drivetrain
    Last Post: 10-06-2006, 06:39 AM
  4. Gear question
    By TheAntiRice in forum Drivetrain
    Last Post: 12-28-2005, 09:20 AM
  5. M6 first gear question
    By third_shift|studios in forum Manual Transmission
    Last Post: 12-25-2005, 07:36 PM
