Results 1 to 11 of 11
    Feb 2010
    canada
    candy red
    2001 ws6 trans am
    Why my ABS INOP lite on?
    My Lite for my ABS INOP is on why?and how can i fix this?2001 ws6
    Member Blue_01_Z28's Avatar
    Midland, TX
    Metallic Blue
    2001 Chevrolet Camaro Z28
    Quote Originally Posted by mannie View Post
    You know I have had the same problem only thing is mine turns off on its own. It usually turns on when I go visit my bother in Las Cruces, NM. When I turn the car off then on again it goes away. I'm not sure whay upgrades you have on the motor but I personally think its from less vacuum from the cam. Or maybe from when i installed the Dana S-60 which was really when the light came on. I hope someone chimes in on this.
    I dont know how to help sorry other than maybe checking the rearend sensor.
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    i had the same prob on my 95 formula. everyone kept telling me it was the sensor on the rear end.... i totaled the car before fixing it though so i dont have a solution for ya... sorry
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Few things to check out....
    First - Have you recently changed tire size? Offset in tire size from front to back can cause this.
    Second - make sure all of your ABS sensor connections at the wheels are plugged in and have not come loose. Also, make sure they are clean. over time the sensor can get dirty.
    Third - If you know someone with a higher end scanner, such as those at a dealership or one a mechanic might use, you can scan the ABS code to get more info. Unfortunately the scanners at places like Pepboys and Autozone do not work for ABS, only OBDII.
    The last thing to check is possibly a kinked wire.
    Most cases it is a faulty ABS sensor, you just need to find which one.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Gonna have to have it scanned, Although you need a ABS scanner to pull the code. It could be one of the wheel sensors took a poo on ya, Dirty sensor, loose wiring harness, one or more of the reluctor wheels are broke. Low brake fluid.
    Best way to pinpoint is to have it scanned...
    "blue01", When you installed your rear did it have provisions for ABS?
    Did they install the sensors correctly?
    Also ABS is great but dont worry, your car will run perfectly fine, The only differnece is when you slam on the brakes your wheels will lock up and wont pulsate like they would with the ABS functioning properly
    J
    Junior Member tdevil55's Avatar
    Nov 2009
    Hampton VA
    Navy Blue Metalic
    02 Z28 Camaro
    I had mine come on once when I blew a buld in one of the rear tail lights. Changed the buld out and it fixed it. That was on a 97 V6.
    Midland, TX
    Metallic Blue
    Quote Originally Posted by sunsetorangess View Post
    J
    You know I'm not real sure about that, but when I ordered it from strange I thought I ordered it with the abs and all that so it would still work. I need to check it though. I know for sure I got it with the Traction control to work as well. I remember installing the sensors that go through the inside of the rears hubs.
    Quote Originally Posted by Blue_01_Z28 View Post
    The may have not installed your reluctor rings on properly.
    When I first got my 9" installed, I had an ABS light pop up. It ended up being a pinched wire from the install. Easy fix.
    Midland, TX
    Metallic Blue
    Huh well ill be.... Was your light on all the time, mine just comes on when I drive for about 300 miles non stop?
    Hmmm. I'll have to think about that one a little more. It only comes on during/after a long trip?
    Midland, TX
    Metallic Blue
    Yes sir
  1. this would be the best Miller Lite commercial ever
    Last Post: 05-15-2009, 03:39 PM
  2. RPM Tac With Shift Lite???
    By Patsy57 in forum Appearance Section
    Last Post: 04-10-2008, 05:29 AM
  3. 2007 HPP Day... Lite
    Last Post: 10-17-2007, 10:40 AM
  4. Low Oil Lite
    By wnmech in forum Internal Engine
    Last Post: 02-20-2007, 01:48 PM
  5. check eng. lite
    By z28jerad in forum General Help
    Last Post: 12-06-2006, 11:59 AM
