Results 1 to 19 of 19
Thread: Difference in SFC brands?
03-01-2010, 03:21 PM #1Electrical Engineer
- Jul 2009
- North of the Motorcity
Is there any difference between the SLP SFC and the UMI SFC, besides UMI is about $50 cheaper?
SLP
UMI
03-01-2010, 03:26 PM #2
Their strength will depend on the guage of metal used to constuct them. Along with the penetration of the welds, and the shape. Sertain bends will add strength to any piece while others will be weak or do nothing. I'd have to have one of each in front of me to determine any of thier possible differences..
03-01-2010, 03:41 PM #3
03-01-2010, 04:22 PM #4
check out BMR SFC's I have them on my camaro and they seem to work pretty well.
03-01-2010, 04:29 PM #5Junior Member
- Aug 2009
- Greenville
Red- 2002 SS Camaro
Dollar for Dollar you cannot beat UMI Performance. The materials are top knotch and they pride themselves on building quality that is made in the USA. Support after the sale is also great! Now aside from UMI as a company their SFC's are superior to the SLP's because they also support the LCA mounting points.
Dan R.
03-01-2010, 04:40 PM #6
Usually round tubular type constriction is stronger provided the two are made from the same type and guage of steel and metalurgy. An arch or circular structure by physics tends to be very stong and less likely to "crush".. Square tubing while very strong in it's own right, gets it's strength from it's 90* corners only. Round tends to be strong along it's entire surface area or circumferance(sp).
03-01-2010, 05:28 PM #7Electrical Engineer
- Jul 2009
But BMR doesn't make a 3 point connection, which I've read is the best way to go for SFC. Compared to 2 point, I'm sure they're a good product, but I'm looking into the 3 point for my car.
Makes good sense. But (I realize this question may not be able to be answered without proper tests) I imagine that the strength of the 90*'s in the square tubing should be stronger than any point in the circular tubing. With that said, the flat portions of the square tubing would be weaker than any point in the circular tubing. So that would lead me to wonder if the total strength of the square tubing would be greater than the circular tubing. I guess this also depends on which way the SFC get torqued...
(This difference is probably small enough to be neglected and I'm wasting my time putting this much thought into it)
03-02-2010, 11:33 AM #8Life In The Fast Lane..!!
- Jul 2008
- SoCal, SD
Brickyard 400 Trac Car#10- 35th Camaro SS/LE Vert
Get the UMI. they also tuck up real nice.
03-02-2010, 12:13 PM #9King 0f n00bz
- Jan 2006
- Shepherd, Michigan
umi. [/THREAD]
03-04-2010, 11:18 AM #10Electrical Engineer
- Jul 2009
I'll have to get the UMI's for tax time. Thanks for all the input.
03-04-2010, 11:25 AM #11Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
I have the slp connectors they dont tuck up as well as the umi ones I have seen
and they are heavy
03-05-2010, 12:13 PM #12
I dont know or think Kenny Brown makes them anymore but the ones on my car are light and tuck up really nice. I have to really try hard to see them underneath the car. You would have to get on the ground and look up a bit to be able to see them. Im very happy with mine.
1993 Z28 M6: K&N Intake, 52mm TB, TB Bypass, No Cats, Exhaust Cutout, Flowmaster Muffler, 3.90 Gears, 160 Thermo, Tune, BMR Springs, Bilstein Shocks, 3 Point SFC,s & MGW Shifter.
03-07-2010, 12:40 PM #13
03-08-2010, 04:56 AM #14Member
- Feb 2008
- NEW JERSEY
I dont know about umi but the slp connectors are heavy
03-09-2010, 10:53 AM #15Electrical Engineer
- Jul 2009
Do any of the three point SFC interfere with aftermarket exhaust setups? (namely longtubes and ORY)
03-09-2010, 11:12 AM #16
03-09-2010, 12:22 PM #17
I had a set of SLP on mine and I liked them. Car is totaled now. PM me if you want to buy a used set.
03-10-2010, 09:29 AM #18Junior Member
- Nov 2009
- Kansas
Pewter- 1999 Formula Firebird
I just got my UMI SFC in and they look strong and rigid, they also forgot the hardware pack (Bolt in) but they where very speedy and easy to deal with and got me what i need fast. id diff. go with UMI aging.
03-10-2010, 11:21 AM #19Member
- Feb 2008
- NEW JERSEY
High performance pontiac did an install artical on slp 3 point sfc
they add about 45 pounds
Opinions on brands
By jts98z28 in forum DrivetrainReplies: 15Last Post: 06-14-2008, 07:03 PM -
Tire brands
By Spikito in forum Wheels and TiresReplies: 17Last Post: 02-10-2008, 01:54 PM -
Is there a difference between brands?
By patriot1136 in forum General HelpReplies: 5Last Post: 07-26-2007, 06:31 PM -
Suspension Brands
By VinceWS.6 in forum Firebird / WS6Replies: 7Last Post: 11-02-2006, 12:28 PM -
Slp Headers Vs. Other Brands?
By SPLIT THIS in forum Firebird / WS6Replies: 3Last Post: 06-01-2006, 05:16 PM
