Thread: Rock Chips
03-01-2010, 08:15 AM #1Member
- Nov 2009
- North Carolina
Black- 2001 Camaro Z28
Rock Chips
So I was driving behind a dump truck today and it kicked up a rock and left a nice chip in my newly painted car
anyone have any trick for covering this up? Its right on the hood and about the 1/32 diameter but still shows up bad on black
03-01-2010, 11:12 AM #2
03-01-2010, 11:35 AM #3
03-01-2010, 03:41 PM #4
Take a match, (the paper kind, from the little matchbooks) cut it on a 45 degree angle with a good sharp blade. Gently DAB the paint into the chip, DO NOT BRUSH IT. Build it up higher than the surface and let it dry. Then take some 1200 or 1500 wet sanding paper, and gently sand it down smooth. Then buff to a high luster, you don't really need a buffer for this, an area that small can be hand rubbed. That's how I always did it, I hope this helps
03-01-2010, 03:48 PM #5Professional Detailer
- May 2006
- Bay Area, CA
Navy Blue Metallic- 98 Camaro Z28
you take out wetsanding marks by hand??? I'd love to see this...
03-01-2010, 03:57 PM #6
03-01-2010, 04:01 PM #7Professional Detailer
- May 2006
- Bay Area, CA
I've never seen it done effectively by hand and I've been in the detailing business for nearly a decade. Even 3000 grit needs to be removed by machine.
Question: Have you repair paint chips or rock chips?
By allbaugh_04 in forum Appearance SectionReplies: 4Last Post: 02-04-2011, 06:12 AM -
Rock chips on hood
By 00hawk109 in forum Showcar and DetailingReplies: 4Last Post: 04-08-2010, 02:41 AM -
Rock chips and scratches?
By One_Bad_TA in forum Showcar and DetailingReplies: 17Last Post: 09-21-2008, 09:27 PM -
SCRATCHES and ROCK CHIPS!!
By wantaLS1 in forum Appearance SectionReplies: 1Last Post: 04-05-2008, 04:00 AM -
how to repair rock chips?
By t.a.joe in forum Showcar and DetailingReplies: 3Last Post: 04-30-2007, 08:34 AM
