Results 1 to 10 of 10
Thread: Y-Pipe Question
    Junior Member Ironwolf's Avatar
    Jul 2009
    Wichita, Kansas
    1999 Trans-Am WS6
    Y-Pipe Question
    I was perusing Ebay for Magnaflow exhaust systems and I came across two that fit my car. One with dual Quad tips and one with dual tips and no y-pipes. Now this is probably a noob question...but is a y-pipe required for installation of this exhaust system on my car? I'd like to get the one with no y-pipe because it will save me about $300 bucks, but I don't want to waste my time and maybe even more money if a y-pipe is required.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Part numbers or links? cant see it can't tellya
    Jul 2009
    Wichita, Kansas
    1999 Trans-Am WS6
    The Magnaflow 16723 (quad tips) will fit your stock Y-pipe. This thread details the install of that system on our car: http://www.ls1.com/forums/showthread.php?t=121606 I presume that the same holds true for their other catback.
    P.S. Check with Mark at KY Speed (site sponsor) before you buy on e-bay. Chances are he may have a better price. You can PM "marksls1ta" to inquire.
    Jul 2009
    Wichita, Kansas
    1999 Trans-Am WS6
    My question though is if the dual tip system that doesn't come with a y-pipe will fit.
    None of the catbacks include a Y-pipe. They are generally designed to interface with both stock and aftermarket Y-pipes. I recently changed out the stock Y to a Kooks catted Y. No issues.
    Jul 2009
    Wichita, Kansas
    1999 Trans-Am WS6
    Ah ok. That makes sense. What are the benefits of an aftermarket Y-pipe?
    Quote Originally Posted by Ironwolf View Post
    Take a look at the driver side of your factory Y. You'll see very quickly what the issue is. An engine is simply one big air pump. The less resistance on the output side, the more efficient the pump.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    They will both bolt up. Neither has a Y so it really does not make since why they even mention that. Like the guys said abouve you don't need the Y to install and the only differance between the two systems are the hardware quality and the ability to use different tips. The cheaper system uses a welded in round tip and regular muffler claps that tend to kink pipe V's the band style clamps in the more expensive one.
    Jul 2009
    Wichita, Kansas
    1999 Trans-Am WS6
    Thanks for the help guys. This makes my choice a lot easier.
  1. QTP y-pipe question
    By dummybait in forum External Engine
    Last Post: 03-24-2011, 05:25 PM
  2. TSP Y-pipe question???
    By lvbroham1 in forum External Engine
    Last Post: 06-07-2009, 06:41 PM
  3. Help: Y-pipe question
    By chevyboy82188 in forum Camaro / SS
    Last Post: 04-28-2008, 06:34 AM
  4. Y pipe Question
    By Italiano in forum External Engine
    Last Post: 03-08-2006, 07:42 AM
  5. Y-pipe question
    By NE98LS1 in forum External Engine
    Last Post: 01-30-2006, 08:08 PM
