Results 1 to 10 of 10
    Pulley Tensioner
    How do you know when your pulley tensioner needs to be replaced?
    NC
    SOM
    1998 T.A.
    Mine have always gotten noisey and/ or wobbly. Get a Katech if you can.....
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    The tensioner pulley or the tensioner spring? I am LT1 so I don't know if there are the same type tensioner. The spring usually will be good for a long time and the pully usually looses the bearing. If you have a bad bearing that transfers a lot of heat to the spring it can weaken it but there are usually marks on the tensioner that show where the tensioner should be. It's a range and it depends on how stretched the belt is. On a new belt the tensioner should never leave the range. If it does the spring could be weak or there may be a problem with another pulley or accessory.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    If your belt starts walking off, or gets completely thrown off, its time to replace. I put a Katech tensioner on mine and it works flawlessly, highly recommend it over a stock replacement.
    Build in progress...
    I'm thinking it may be time for a new belt. I checked it again this past weekend and wasn't getting any noise. I have no idea when the belt was last changed, I've only had the car for a yr and I've been replacing worn out stuff as well as installing performance upgrades. I'm asking only because when I do a medium to hard launch my check gauges light comes on and my volts gauge drops into the 9 -10 volt range , then climbs back up after I get to cruise. I know I have a PS hose leak that's going to get fix somehow this weekend. I hate GM for putting the alternator below the PS Pump. Dumbass engineers.
    Buffalo
    Orange
    1999 Camaro
    Change the belt.
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    Just some food for thought but the voltage and power steering could be connected. ive seen a number on these cars on tech where a hose ruptures and squirts fluid into the alternator causing intermitant shorts just like u describe, eventually it just kills the alternator.
    NC
    SOM
    1998 T.A.
    Quote Originally Posted by redbird555 View Post
    Had this happen to me......
    Pittsburgh
    2008 Hummer H3
    They will also chatter sometimes @ idle and then it will sometimes go away when giving it some throttle.. A dry bearing is easily detected by removing the belt and spinning the pully. If it makes a marble rolling on the floor sound, this is usually a good indicattion of a dry bearing. A dry bearing = a fail will come eventually..
    Thx's all I check into them this week end and will post what I find.
  1. A/C idler and tensioner pulley
    By 94formulaLT1 in forum Parts Wanted / Trade
    Last Post: 11-11-2009, 11:15 AM
  2. tensioner pulley
    By cm2papa in forum External Engine
    Last Post: 12-12-2008, 12:51 PM
  3. For Sale: LS1 Tensioner Pulley
    By Travisnd in forum Parts For Sale / Trade
    Last Post: 11-17-2008, 05:08 AM
  4. Idler and Tensioner Pulley
    By bgable in forum External Engine
    Last Post: 08-18-2007, 03:22 PM
  5. Tensioner Pulley
    By Heartbreak1 in forum External Engine
    Last Post: 06-26-2007, 04:44 PM
