Thread: LS1 lokar dipstick question
02-21-2010, 06:53 PM #1Junior Member
- Feb 2010
- SD
True blue pearl- 1955 Chevy pickup
Hello all,
I recently purchased an LS1 powered '55 chevy pickup. I changed the oil and filter this weekend, and drained the old oil back into quart containers- the total oil drainded came out to just over 6.5 quarts. From what I've read, an LS1 with an f-body oil pan holds 5.5-6.0 quarts max; pepboys (where I purchased the oil) said that it should take 6.0 quarts with a filter change. I added 6.0 quarts and it reads at the low level on the dipstick, which is an aftermarket Lokar.
One big question I have is if the Lokar dipstick works for all LS1's reguardless of the oil pan (vette or f-body). I contacted Lokar and they said they only have one dipstick for LS1's- they seemed kinda clueless as to the f-body oil pan, he kept saying "it's out of a vette, right?" I explained that there is a difference in the oil pans and he replied "I've always put 6 quarts in every LS1 i've ever done." Needless to say, this was less than helpfull.
I feel I should trust that 6.0 quarts is correct, rather than just going by what an aftermarket dipstick is reading. I just need a little piece of mind on the matter
Any thoughts or opinions are appreciated greatly!
02-21-2010, 07:09 PM #2Junior Member
- Feb 2010
- SD
Am I right to ignore the aftermarket dipstick and just put in 6.0 quarts of oil. I have an LS1 out of a 98 camaro.
02-21-2010, 07:21 PM #3
I can only tell you what my 98 holds stock and that's 5.5 with a filter change.
02-21-2010, 07:32 PM #4Junior Member
- Feb 2010
- SD
thanks...any input helps! Does that put at the full level on the dipstick, or just in the upper area of the hash marks?
02-21-2010, 07:36 PM #5
that's full and what the owners manual calls for on a oil and filter change. what filter are you running? The stock pf46 filter is what I use but if you use the truck filter (pf51 I believe) you can fit 6 quarts in there.
02-21-2010, 07:42 PM #6Junior Member
- Feb 2010
- SD
I used a mobil 1 filter p# m1-107. It should be standard size- holds 1/2 quart.
02-23-2010, 04:35 AM #7
I use the extended M206 filter, and my 01 Z28 takes a bit over 6 qts. to the full mark on the stock dipstick.
SteveC
Lokar Competitor Series Throttle Assembly - Ready To Ship
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-28-2013, 10:00 PM -
Lokar's Drive-by-Wire Throttle Pedal
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 01-16-2013, 10:10 PM -
Lokar's Billet Brake And Gas Pedal Throttle Assembly - Press
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 09-17-2010, 03:20 PM -
Lokar, QA1, SLP, TSP, Speed Inc
By xssive in forum Parts For Sale / TradeReplies: 1Last Post: 05-09-2006, 06:57 AM
