Results 1 to 20 of 22
Thread: Poor Idle on 3800-II
02-21-2010, 11:51 AM #1
Car in question is a 1996 Camaro V6 with the 3800-II motor.
When I first start it, it revs up to about 2200RPM and stays there for a few seconds and the idles down to roughly 1200RPM and stays steady.
Once it has been running about 30 seconds or so, it begins to idle erratic. The idle will go from 800 (almost dies here) to 2000RPM....and continues to do this.
If I rev it up and let my foot off the gas, it will also stay at that RPM for several seconds before coming back down.
The SES light is on. I pulled 3 codes.
P0171 (System too lean, left bank on 4 sensor systems)
P0174 (System too lean, right bank)
P0300 (Engine misfire detected).
I've tried cleaning the MAF and that made no difference. My next thought is possibly a vacuum leak and this is causing the idle problem also?
Thanks for any input. I don't drive this car hardly at all and am just trying to soak as little as possible before I try to sell it come spring time. Oh, and the car has 209,000 miles on it! Car drives fine other than the idling.
JM
02-21-2010, 12:18 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Could be vacuum leak, possibly O2 sensors if you've got them. Off chance it could even be bad gas depending on if you store it or just filled it somewhere - has happened to me a couple of times.
02-21-2010, 12:27 PM #3Senior Member
- Oct 2008
- Coral Springs, Fl
Is that thing still alive
Check your coils
02-21-2010, 12:34 PM #4None Shall Pass
- Jan 2010
Wouldn't coils cause a too rich code?
02-21-2010, 01:02 PM #5
Sounds like a vacuum leak or something has broken or loosened up and is allowing unmetered air into the engine. Do they have Idle Air Control valves or anything like that?
02-21-2010, 03:45 PM #6
I'm guessing a vacuum leak somewhere....check hoses and intake gaskets.
02-21-2010, 04:05 PM #7
The 3800-II only has 3 vac hoses (not sure on the 96) could be one but doubtfull. Have you checked to be sure your PCV still rattles? Also check your fuel vapor purge solenoid (will not throw a code if bad) for proper operation. Then there's always the digi EGR.. A bad MAP may cause this too..
02-21-2010, 04:13 PM #8
I did pull the PCV and cleaned it. She still rattled and wasn't too gunked up.
Looks like it probably is a vacuum leak from all the responses. I'm going to be pulling hoses and checking them as soon as the weather gets a little warmer. The car sounds like it's got a big choppy cam in it when it's at idle.
02-21-2010, 04:14 PM #9
02-21-2010, 04:15 PM #10
02-21-2010, 04:22 PM #11
02-21-2010, 04:24 PM #12
02-21-2010, 04:26 PM #13
02-21-2010, 06:38 PM #14Senior Member
- Apr 2008
- Madison, WI
Yep high idle and lean codes on both banks is almost definitely a vacuum leak
02-21-2010, 11:28 PM #15
02-22-2010, 03:19 AM #16
Thanks for all the responses and feedback. I'll be looking into it this weekend. I'll let you know what I find.
Steven - It had been sitting outside for the longest time before I pulled it into the garage. I wouldn't be surprised it the hose going to the back of the intake is rotted.
02-22-2010, 05:36 AM #17
07-04-2010, 07:30 AM #18
OK so I've been busy as all hell and the car hadn't been a priority......BUT...I finally looked at it this morning.
Found 2 things wrong.
1st is..YES..a vacuum leak. The intake is leaking. When I spray it along the entire fuel rail the engine idle changes. So I'm confident that the intake needs to come off and the gasket replaced.
2nd thing is the check valve on the fuel pump is bad. Not really too worried about this, but once I turn the car off the fuel pressure drops slowly and when I go to start it, it takes a few turns before it starts so I'm guessing this is why it is doing this. Taking time for the fuel to get back up front.
07-04-2010, 08:24 AM #19Senior Member
- Oct 2008
- Coral Springs, Fl
It's still running
At least you're getting closer at solving the problem. Before you try and start it just turn the key once or twice before to prime the system.
07-13-2010, 04:11 PM #20
Hey V6 Doc....
Any tips on getting the intake out? I know you just took yours out to paint it so I thought I would ask while still fresh in your mind.
I have the air duct out, the throttle body off, serpentine belt off....now I'm trying to get the fawking alternator out. Not budging. I have a Hayne's manual I am using, but it's pretty much useless in my eyes.
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 03:36 AM -
warm/hot start HIGH rev idle/ sticking throttle??3800
By rschap1 in forum V6Replies: 18Last Post: 04-03-2012, 03:56 AM -
Poor idle when radiator fan comes on?
By Larry in forum Computer & TuningReplies: 11Last Post: 12-20-2007, 11:11 AM -
poor dyno numbers? and poor exhaust
By xzaero0 in forum Firebird / WS6Replies: 10Last Post: 07-22-2007, 09:45 AM
