Results 1 to 2 of 2
02-20-2010, 10:16 AM #1Member
- May 2008
- New Brunswick
Handlind & Racing set up...coil overs vs koni
I'm both a drag racer and autoXer, currently I run 275 front 315 rear Nitto 555 tires and have 3pt sub frame connectors, a strut tower brace, and solid front and rear sway bars. I also have a decent street/race alignment.
I like the way the car handles but I have 2 issues, for one I don't seem to have excellent traction off the line, and secondly I can't hold as much speed through corners or change directions as quickly as smaller cars.
Can anyone make a suggestion as to what further mods might gain me the most handling increase? While improving, or at least not hindering my ability to launch.
As a separate but related topic I am currently wondering if I should go with a coil over set up such as this: http://www.stranoparts.com/partdetai...D=21&ModelID=8 or if I should go with Konis and stay on stock springs??
I say stock springs because I can not lower the car more than a 1/2" (I have reasons) and all aftermarket springs I see have more drop then that. Though I've wondered about the use of aftermarket springs (like the strano 1.2" lowering springs) with some kind of mounting pate that is about 3/4" thick to keep the drop from exceeding a half inch, after the install is completed.
02-20-2010, 11:07 AM #2
Drag-racing and auto-crossing have totally different shock requirements as far as what works best.IMO, I would have to say Koni Da's with stock springs since you really need to be able to adjust both the rebound and compression dampening to do both effectively.
I would still highly recommend talking to Sam Strano about you choices, since one way or another you're going to need to make a compromise on your wants.
variant coil overs ( 2 or 3) series
By jonnyman in forum Suspension and HandlingReplies: 2Last Post: 03-11-2014, 05:55 AM -
coil overs
By blackbirdbrain89 in forum Suspension and HandlingReplies: 5Last Post: 11-17-2007, 07:04 PM -
Coil overs or something else? NEWB to suspension.
By Heartbreak1 in forum Suspension and HandlingReplies: 12Last Post: 09-07-2007, 03:22 PM -
coil overs?
By tawhite160 in forum Suspension and HandlingReplies: 6Last Post: 10-22-2006, 04:39 AM -
Rear Coil Overs??
By sk8runeg in forum Suspension and HandlingReplies: 2Last Post: 02-21-2006, 08:44 PM
