Results 1 to 18 of 18
Thread: Going Insane, Need Help
02-20-2010, 06:48 AM #1Junior Member
- Oct 2009
- Mississippi
Navy Blue- 1999 Trans Am
A few months ago a terrible squeak began under my hood. Alright replaced the belts, didn't work. Then I began spraying belt dressing around certain areas to determine the pulley that was making the noise. Conclusion, the alternator. No biggie it probably needs to be replaced anyways. So I replaced it and when doing so I spun all the other pulleys to check for sounds. None were found but sure enough when I put the belts back on and started driving the noise slowly came back. Then a few weeks ago I notice engine coolant everywhere. Water pump was in terrible shape. Replaced it knowing that was the cause! Wrong, mug still squeaks.
Anyone else had this problem and know what it is? I happens only when the gas is pressed. It's very mild at idle but horrible when the throttle is open.
Nothing like a beast of a machine that squeaks louder than it's exhaust! lolLast edited by navyLS1; 02-20-2010 at 06:50 AM.
02-20-2010, 07:05 AM #2
I've posted on this topic before -- some belts tend to be noisier than others. Have you tried a different brand belt? We run a Goodyear Gatorback on ours and have had no noise. Also, did antifreeze get on the belt when the water pump went south on you?
02-20-2010, 07:11 AM #3
02-20-2010, 07:24 AM #4
Idler pully imho.. Sometimes pulleys won't squeek until under presure from the tensioner pulley and the motor driving the pulley..
02-20-2010, 07:50 AM #5
02-20-2010, 03:26 PM #6Junior Member
- Oct 2009
- Mississippi
Idler and a new brand belt. This is turning into a money pit real quick...anybody wanna buy it haha. JK
02-20-2010, 04:58 PM #7
02-20-2010, 05:16 PM #8Junior Member
- Oct 2009
- Mississippi
Ok is there a difference between an Idler pulley and a AC Idler pulley?
02-20-2010, 05:56 PM #9Senior Member
- Apr 2008
- Madison, WI
yes. there's 2 belts. you want the main serp belt idler pulley.
02-20-2010, 05:57 PM #10Senior Member
- Apr 2008
- Madison, WI
And definitely try the gatorback belt! its a great noise fixer
02-20-2010, 06:23 PM #11
02-20-2010, 07:57 PM #12Junior Member
- Aug 2009
- Clovis, California
Sunset Orange- 2002 WS6 Trans Am
A neat trick my friend's dad taught me was; get a long solid metal rod (no pun intended) and while the car is running u can put it on some of the pulley's n then put ure ear on that rod, from that point u can hear or feel that noise travel through the rod. thats how i found out my ac pulley was bad
02-20-2010, 08:02 PM #13
A piece of wood will also work - you just have to be real careful. Usually, if belt dressing does not quiet it down then it has to be a pulley or one of the belt driven accessories that is squealing. If it is the AC belt you will usually hear a change in noise by triggering the compressor. It will slip worse momentarily as it comes under load.
02-21-2010, 12:20 AM #14Junior Member
- Aug 2009
it just has to b a solid object really tho so the noise/vibration travels
02-21-2010, 04:27 AM #15Senior Member
- Apr 2008
- Madison, WI
pulley misalignment can also cause belt squeal. The edge of the belt squeals against the edge of the pulley. So if you think your alternator is misaligned you'll have to try to fix that. I've also seen power steering pump pulleys that weren't pressed on all the way or pressed on too far that cause misalignment/squeal.
02-21-2010, 05:37 AM #16Junior Member
- Oct 2009
- Mississippi
02-21-2010, 06:09 PM #17Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
+1 for the Idler Pulley....
02-21-2010, 10:22 PM #18Drivin It Like I Stole It
- Dec 2005
- Tampa, FL
Pewter- '00 TransAm WS/6
Squeaky belt
Actually, the noise could come from all kinds of places. The belt is the obvious first suspect. The idler is another common one. It could actually be anything that moves, so any of those pesky accessories could be the cause.
I had an alternator once (on a regular smallblock Chevy) that squeaked. Since it burnt through alternators for some reason, I just lived with it until it died, and exchanged it for a new one (gotta love "lifetime" warranties)
You'll have to go for the good old fashion funny noise test. Turn your head so only one ear is towards the engine, and move your hand around until you make the noise quieter. If you're practiced at it, it looks like you're fixing the car with voodoo, which is always entertaining. "How did you know that's the broken part?" "the spirits speak to me, and say your alternator is failing."
This is insane
By Sarge in forum Almost Anything GoesReplies: 50Last Post: 01-30-2010, 07:53 AM -
Insane!!
By blackSS01 in forum Almost Anything GoesReplies: 14Last Post: 09-03-2009, 10:06 PM -
insane speedometer
By 02transamce in forum V6Replies: 1Last Post: 12-24-2008, 01:05 PM -
I Have Gone Insane!!!
By 2001somws6 in forum Showcar and DetailingReplies: 44Last Post: 08-19-2008, 09:29 PM -
Insane or not insane
By redls1 in forum Almost Anything GoesReplies: 43Last Post: 10-24-2006, 06:50 AM
