    Stockitie Stock Stock 95camaroZNC's Avatar
    Raleigh NC
    1999 Trans Am
    Picked up some flowtech longtubes need advice
    Looking to run true duals with a dump before the axle with turn downs. What all will I need? Do I need more the one set if o2 sensor Sims?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    you need to keep the front O2 sensors and get rid of the rears. O2 sims don't work as well as tuning them out of the computer. You'll need a tune anyways to get the most out of your headers. alot of people can't hardly get their car running right without a tune after headers because it changes the air/fuel ratio that much.
    Member squirlnutz's Avatar
    oklahoma
    2000 trans am
    My car had headers when I bought it. The car went 12.8x with a ported throttle body, Granettelie? mass air, smooth lid, bla,bla,bla. Plenty of bolt on goodies. Hell, thats why I bought it. No lights ever came on even with open headers! Before you do headers make the most of your money and hard work and have your car tuned by a pro. Check and see around your area and see if you can find a reputable tuner with a rear weel DYNO to give your car the right tune for your mods.
    Raleigh NC
    1999 Trans Am
    Ok well next question is running true duals dumped before the axle where are both sets of o2s and how do i go about getting rid of the 2nd set easily? Or if i dont have a tuner?
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    You will need some o2 extensions for your fronts since the o2 bungs will be lower, and the rears are as easy as unplugging, get underneath your car an you will see the rear o2's behind the cats real quick.
    Raleigh NC
    1999 Trans Am
    Kit came with extensions luckily
    Quote Originally Posted by 95camaroZNC View Post
    unless they're pre-made extensions don't use them. Don't use the ones you have to splice wire into and extend the harness......time and time again I read about people having problems with those. It'll possibly save you a bucket full of headache and only cost ~$40.
  1. Question: Flowtech LT's
    By 01SsRacing in forum External Engine
    Last Post: 06-08-2013, 06:48 AM
  2. Flowtech Headers
    By TransAmcoupe98 in forum External Engine
    Last Post: 06-02-2007, 07:07 PM
  3. Flowtech
    By slpws6ta in forum External Engine
    Last Post: 01-07-2007, 01:32 PM
  4. FLOWTECH Header ????'s
    By LOWnMEAN in forum External Engine
    Last Post: 11-09-2005, 02:14 PM
  5. flowtech exhaust cut out!!
    By ibanez7 in forum Parts Review
    Last Post: 09-01-2005, 12:09 PM
