Results 1 to 20 of 21
    Polished something... other than my knob
    Working on my header install (and everything else), I have been looking at my grungy rocker covers for the past two weeks. I just couldn't take it anymore, so late last week off they came. Even though the first cover cleaned up nicely, it was pretty rough around the edges and there were a lot of casting marks.
    I started with a sanding disc to knock the casting flash off the perimeter. I then used a fiber dryloc to blend in the casting blemishes before using 320 wet on the rougher areas and 400 wet on the entire cover. I then buffed it and finished it with a sealer coat from 200 MPH.
    Here's the right cover as it came off the car and the left cover completed, along with one of the left cover back on the car. I have some new pieces coming for the PCV setup, so the hole is covered by a piece of duct tape in the picture.
    It's not perfect, but it is a whole lot better than it was when I started. Once the coil packs and FRC's are back in place, I realize only a bit will peek out. Yes... I am way too obsessive-compulsive.
    Forgot to post my question. The service manual states that if the oil fill tube is removed from the rocker cover that you need to buy a new one. I have no idea if there is an o-ring on it or what seals it. Any truth to this? Just want to know if I should leave it alone or if I can pull it out to make more room to work?
    Member zeetwentyeight's Avatar
    Aug 2009
    A, A
    1998 Camaro Z28
    Looks really good man, and im not sure on your question
    looks great jeff!!! You're right, that's a shame you'll barely see it.
    Yes, it's true-it'll break upon removal.
    Thank you. Guess I'll just have to tape it off and be careful not to hit it with the shank when I buff it.
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    they look good i may have to do this on my car. jason what is the cost on the new filler?
    The reason it says you will need a new one is because you basically have to break it to get it out. I think they run $5-7 though, not pricey by any means. I think I have been able to successfully remove 1 of 4 attempts without breaking the damn thing. They are a major PIA, don't remove it unless absolutely necessary.
    They look significantly better Jeff, I have a 2nd set I have thought about just polishing as well.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Those look great! Ive seen some others do this and always thought about it. Now do a coil relocation so you can show them off!
    +1 on the filler neck. Damn near impossible to take off without trashing it. I didn't even think it was possible honestly.
    Pittsburgh
    2008 Hummer H3
    Looks good Jeff! My cars are next!!
    Dam P..!? Did ya get powdered donut dust on it when you were eating off your motor??
    I can't honestly think of any other reason you'd have to pull your tube out other than to clean it J/K
    When I was getting the covers powdercoated was the first time I broke one. I successfully removed the tube the 2nd time and the trick was wedging a small small flat head screwdriver in between the tube and the "track" its locked into. If you can get the screwdriver in there to break the lock, it will twist out, but I have still broken tubes attempting this too. Its a PIA even trying this way.
    Thanks for the replies! I guess I will leave the filler neck alone. It has just a bit of "wiggle" to it, so I thought that it may be removable. The good news is that the right cover does not have anywhere near the casting imperfections that the left one had. Should be a much easier job.
    Pittsburgh
    2008 Hummer H3
    Shortly after I usually think that something gets thrown across the garage..
    Fortunately, I have about double the patience of most people. I have never thrown anything in frustration and a muttered curse is about tops for me when I am working in the garage.
    That right there tells me you have not worked on any, or very few Ford products
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Great job Jeff. Car is going to look like a brand new one come spring at the rate you're going at.
    Pittsburgh
    2008 Hummer H3
    Hey wait guys I did'nt word that statement right. Usually the part I'm trying to polish gets grabbed out of my hands and gets flung into oblivion.. I never throw tools much hate chasing them I'm too .. Best tools for fixing Fords is a 10 lbs sledge and a bottle of 100 proof..
    We have Fords too. A '98 Ranger that is now my stepson's secondary vehicle and an '04 Ranger that is my DD. The '04 had quite an appetite for parts the first year or so that I had it.
    Thanks. I just can't leave well enough alone.
    Certainly sounded like you were a tool chucker from your post. I will give you the benefit of the doubt.
    Pittsburgh
    2008 Hummer H3
    Gee thanks you're all heart..
    Finished the passenger side cover tonight and re-installed it on the car. Could have spent a lot more time on them, but since they are basically covered up anyway its probably not worth the effort.
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Well from the looks of it, it was time well spent.. They look trick I likey. Can you coat them with something to keep them nice? I hate the dreded white powder looking corrosion AL. gets over time..
  1. Let Me See Your Knob
    By Z28boy2000 in forum Appearance Section
    Last Post: 05-04-2010, 01:35 AM
  2. Wanted: ls2 gto knob
    By Kaotic_ws6 in forum Parts Wanted / Trade
    Last Post: 02-10-2010, 07:01 PM
  3. Question: m6 gto knob
    By Kaotic_ws6 in forum GTO
    Last Post: 10-30-2009, 07:17 PM
  4. a/c control knob
    By 04cosmos in forum GTO
    Last Post: 06-13-2009, 07:31 PM
  5. will a c5 knob fit
    By kolkid in forum General Help
    Last Post: 09-25-2005, 04:31 PM
