Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Spark plugs
    Junior Member proud1's Avatar
    Feb 2010
    Pearsall, TX
    2002 Trans Am WS6
    Spark plugs
    I have an 02 WS6 and going to change spark plugs every thing is stock wanted to ask would you go with stock or a hotter plug
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    ac delco irridium....ftw
    NGK TR55 plugs gapped at .054".
    The Silver Bullet LS1_ws6's Avatar
    Apr 2009
    Brush Colorado
    1999 Trans Am
    You should go with these
    Junior Member tdevil55's Avatar
    Nov 2009
    Hampton VA
    Navy Blue Metalic
    02 Z28 Camaro
    ^^^ +1
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by needls1again View Post
    I use these in everything I own (car wise) I like them, and been using them for years.. One will change wires more times than they will change their iridium plugs.. I 've heard good things about the NGK tr55's but not enough to switch to a copper core plug..
    Oct 2009
    pewter
    99 trans am
    i put them in my formula and it made a notable difference. pulled em out 6 mths later and still looked great. of course they were a little pricey at $7 each..but oh well.
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    They're a 100k plug I pulled the originals out @ 80k and they looked like new (aside from discoloring from use). Replaced with same set and then a set for the TDC. Changing the plugs on a TDC rivals the f-bod LS1 in difficulty... I did'nt want to have to change them alot..
    I agree -- my stock plugs looked great after 73,000 miles. I still went with the TR55's as I will never leave a plug in a motor for that long irrespective of its intended life (we purchased the car with 71,000 miles on it). The plugs aren't that bad to do if you remove the coil packs and go get the infamous number 8 from beneath the car.
    Pittsburgh
    2008 Hummer H3
    they're no easier on my 6er f-bod either lol, but the TDC? huh you'll either be trying to lean the motor, (TDC can't be tilted and pinned easily no dog bone loop for pinning the engine) or get out the tool sets cuz you'll be pulling the upper intake.. Or pulling off the cowl weather strip and using 90 feet of extensions to get down into the hemispherical heads where the plugs sit either way you'll be there a while ..
    Oct 2009
    pewter
    99 trans am
    well somehow a small friend of mine (happens to own a c5) got the #8 out from the top without lifting the motor...hes a wee little fella
    college station, tx
    sold: 1999 firebird
    not from me you wont
    Pittsburgh
    2008 Hummer H3
    I believe your beast requires Denso's stock..
    Junior Member WS6 > SS's Avatar
    Oct 2009
    Jacksonville
    I agree, I just changed mine to the TR55's. They were not 7$ a piece though! Advance auto parts sold them to me for $2.49 each. BTW, good luck with the rear passenger plug, it's a son of a B$%CH to get to! Also, the owners manual calls for the plugs to be gapped at .060, not .054.
    Pittsburgh
    2008 Hummer H3
    Wink
    Quote Originally Posted by WS6 > SS View Post
    .054 = hotter spark. Just an fyi..
    Iridiums pay for themselves after nearly 3 sets of Tr55's..
    Pittsburgh
    2008 Hummer H3
    On a side note, along with my statement above. Is labor, prolly also saving 6-8++ hours of labor total on three sets Tr55 changes as opposed to 1-2 hours every 2 or so years.. Unless you don't DD the car.. Even then Tr55's are not cost effective for the minor if any real performance gains. I think most people buy the Tr55 cuz they're cheap..
    Feb 2010
    Pearsall, TX
    2002 Trans Am WS6
    ok due to any of my auto part stores not having NGK I bought the AC Delco's but question is what gap should I go with there the iridium plugs
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    I agree about the AC Delco Iridium plugs, they are excellent.
    However, I do not agree with your theory of .54 creating a "hotter" spark.
    Spark gap is about the flame front and ignition system voltage. High voltage systems (such as the LS1 coil-over-plug system) can jump larger gaps due to the higher voltage. So by expanding the gap, you get more exposed flame between the electrodes, resulting in better combustion. A gap such as .060 is not possible with conventional distributor ignition systems, because the spark is not strong enough to jump such a large gap.
    Quote Originally Posted by Wesman View Post
    The difference between the two is .006" -- trivial imo. It was the recommended gap that I went with for the TR55's. As I often say on here, a person can do whatever they want with their own car. If they want to run Royal Purple, a K&N and WeaponX spark plugs, then go for it.
    Member marksls1ta's Avatar
    pikeville, kentucky
    1998 trans am
    TR55 for the NA cars.
    we have them less than $7 ea lol
    Thanks,
    Mark
  1. Enerpulse Pulstar Spark Plugs - Supersize Your Spark
    Last Post: 03-15-2013, 09:00 PM
  2. Question: Spark Plugs
    By 10erg01 in forum General Help
    Last Post: 03-27-2010, 08:53 PM
  3. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  4. spark plugs, tr55 iridium or plane tr55 plugs?
    By got-a-ls1 in forum General Help
    Last Post: 02-09-2006, 06:06 PM
