Results 1 to 20 of 23
    Member JAX04's Avatar
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    2004 Pontiac GTO PBM A4
    Dual Pumps in tank???
    First of all, is it possible to do two pumps in the stock tank??? Secondly, What would be invlolved,
    and lastly, is it possible to run a walbro 255 in conjuction with the stocker??
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    GMHTP has had write ups of cars using dual Walbros in the tank. I dunno what exactly you have to do. I think the twin pumps take up the space of the factory single unit. Keeps the motor from leaning out/blowin up from fuel starvation. Pretty snazzy setup IMO. But I dunno if it would be wise to run a Walbro as a "helper" pump. Someone will add more info as this thread goes along.
    Pittsburgh
    2008 Hummer H3
    Subscrbed....
    Retired Outlaw Sum Bitch
    Why? I run a serious 408 Stroker.....have a Walboro 255 and never see under 60lbs of fuel pressure even at WOT.
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    y?
    Well, I dont know why, lol. maybe just to do it, or was just curious if possible. Im converting to e85 with my turbo build and will be around 500whp. so i have no idea what the 255 is good for on the corn juice. and i was thinking more like the walbro is the main pump and the stocker would be the helper.
    Pittsburgh
    2008 Hummer H3
    Lightbulb
    Quote Originally Posted by JAX04 View Post
    y?
    If your main pump puts out more psi. than the stocker then the stocker is'nt going to help the new pump. More likely it would serve to choke the main pump off and one of the pumps prolly won't last long in a in-line comfig (if that's what you mean). Could be more trouble than it's worth. I'd just get a good single pump and go from there..
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    the thought was to "T" them together in the bucket. like how Fbodies do it. I could be way off base here, but if they were "t" together, their pressures would stack?
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    i think the single walbro would be more then enough for 500whp on the corn juice. But i like the added insurance. Makes me feel all warm and fuzzy inside.
    Pittsburgh
    2008 Hummer H3
    I imagine they might if the 2 pumps produce equal pressure. I would surmise, that if one was producing less presure the other may serve to "stall" the weaker pump and cook it.. I'm sertainly no expert, but I have worked with many different makes of pumps (usually not automotive) hydro statics ect.ect.
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    i agree, i work in the feild of geothermal, i deal with system design based on flow and feet of head all day long. but i do it in a closed circuit where the water is returning to be pumped again. So not only do the pumps have to achieve a certain GPM, but they have to do it at a certain ft/hd. but this is different to me since the pumps will be pulling from an open source without pressure.
    y?
    I am over 600 with one.
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    interesting, isnt true that FI is harder on teh fuel system?? Im just going off of what ive read other places.
    you should talk to qwkgto on here.....he either does or has ran twins in the tank I believe.
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    thats because you have a na car ,around 700 na it would be maxed out,need two on a FI car because the boost ref regulator increases fuel pressure as boost increases. one pump runs all the time second only kicks in duing boost.
    2005 GTO
    yes and its easier to heat the fuel up,I have experimented with all kinds of setups,and found the best way to do this in a FI car,I had the twin intank 255s they did alright up too around 850 rwh after that I was having problems,I now run a stock intake pump and a Weldon 95 psi pump as a secondary, and a sumped tank I built..also going to add a MSD boost a pump to the second pump this makes it have 23 volts under full boost,saves a guy from going exoctic on the injectors. I have for example ,80 lb injectors last year my car was saying that the injector duty cycle was 125-135 no way that was right,with those INJ. should be good for 1350 HP. so the boost a pump should do the trick, MSD has the new adjustable Boost pump.IT uses a laptop,ill let you know how it works out soon as this damn snow is gone here in OHIO.
    I have a twin 255 setup in a bucket all wired and ready,im sure with the boost a pump it will work just as well,ill make u a deal if your interested.
    2005 GTO
    If you are running alcohol one is NOT enough takes more to do the same HP on alky,if you running gas its fine,its about volume not so much pressure.pressure comes into play when you have a boost reference regulator,then you need both.
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    thanks quick
    2005 GTO
    here is a shot of my setup from the trunk
    I do not know why you dont just put a Kenne Bell BaP on there and call it a day....mine has performed excellent for over 4 years now....
    2005 GTO
    I am putting one on as well,MSD boost a pump that way I wont run out of fuel with those 80lbers.
  1. El Mirage Dry Lake Tank Testing - Tank Rodding
    Last Post: 04-07-2011, 02:00 PM
  2. Replies: 0
    Last Post: 09-25-2007, 08:11 AM
  3. HELP: empty gas tank, but cant put any gas in tank
    By 70ssrag in forum General Help
    Last Post: 08-31-2007, 08:16 AM
  4. Replies: 0
    Last Post: 02-05-2007, 03:06 PM
  5. FS: Complete header back with SLP Dual/Dual for Pacesetter(pics)
    By Larry in forum Cowhands, Local Parts and Fish Bait
    Last Post: 05-27-2006, 11:19 AM
