Results 1 to 3 of 3
Thread: window motor
02-10-2010, 05:37 PM #1
window motor
how hard is it to change out the window motor to my 02 Trans Am. Also what kind of plugs are you all using looking to change mine tomorrow just asking to see what you all are using on your Trans ams
02-10-2010, 05:57 PM #2Member
- Tulsa,OK
Quick Silver- 2002 Z06
The window motor is not that hard. You should do a search on AutoTrix and read up on our window fix kit. It will help make sure you are not doing this again in a couple years.
You can find links to free instructions on replacing the motor along with other items in my sig.
As for the plugs, I recommend stock plugs unless you have a NOS or Forced induction setup that requires a hotter/colder plug.
The stock plugs are really good plugs.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
02-11-2010, 08:38 AM #3
Follow the instuctions in the above link and you won't have any problems. I llke to use a spring clamp instead of a screw driver to hold up the window. Whatever looks good to you. Its a pretty easy repair.
Window Motor
By new2dgame in forum General HelpReplies: 2Last Post: 06-22-2010, 12:34 AM -
need help with window motor
By 01pewterZ in forum General HelpReplies: 10Last Post: 12-17-2007, 11:10 PM -
Window Motor
By NewLS1 in forum General HelpReplies: 9Last Post: 12-17-2007, 03:53 PM -
Window Motor Mod??
By CamaroFan71 in forum General HelpReplies: 6Last Post: 10-12-2006, 07:36 PM
