Results 1 to 1 of 1
02-10-2010, 08:40 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
NANO Nitrous System - Nitrous Helper
NANO stands for Nitrogen-Assisted Nitrous Oxide, and it's a bolt-on that regulates bottle pressure for more consistent performanceIn a typical nitrous oxide system, as the nitrous releases, the bottle pressure drops, which reduces the amount of nitrous delivered to the engine. That also changes the nitrous-to-fuel ratio, changing the tune-up and power output as the car goes down the track. There are fixes, such as bottle heaters (the higher the temperature, the higher the bottle pressure) and what's known as a push system that raises bottle pressure by injecting nitrogen into it. But a heater is only marginally effective, and push systems come with their own sets of problems. They are uncontrollable because they use regulator valves that are set to a singular release rate, have a small orifice, and are not rated for constant flow. All these factors lead to lean/rich spikes that can be deadly to your engine, and pressure in the bottle can reach dangerous levels. The bottles used for these systems are not DOT approved and not large enough to be efficient.inline_mediumwraptextrightConsistent nitrous delivery means more performance and is the goal of the NANO system.27927070/techarticles/engine/hrdp_1003_nano_nitrous_systemhrdp_1003_01+NANO_nit rous_system+.jpgTrue
Photo Gallery: NANO Nitrous System - We Test The Latest Nitrous Oxide Bottle Pressure Trick - Hot Rod Magazine
More...
Zex LS1 Nitrous System wet.
By karpetcm in forum Parts For Sale / TradeReplies: 3Last Post: 12-01-2010, 05:48 PM -
TNT, Nano, 860, Auto Meter, ZEX, Nitrous outlet
By ICRAZY6 in forum Parts For Sale / TradeReplies: 9Last Post: 05-13-2010, 08:26 AM -
Nitrous System Testing - Nitrous Mythbusting
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 06-22-2009, 08:50 AM -
Wtb Nxl Nitrous System
By sscrazy in forum Parts Wanted / TradeReplies: 2Last Post: 06-26-2007, 06:16 AM
