Thread: Rear Sway Bar question?
02-06-2010, 07:21 PM #1
- Nov 2009
- Kansas
Pewter- 1999 Formula Firebird
So im going to order my UMI bolt-in SFC(or would Weld-in be better in the long run) in a few days but i was looking at there Rear sway bars too, I was just wondering will a stronger Rear sway bar really help that much at the drag strip or is that money better spend eles where? Im trying to get some of the basic cheap suspension upgrades out of the way in the winter time now before i jump into the motor in the summer.
Thanks
02-08-2010, 10:58 AM #2
- Jul 2008
- new jersey
navy blue metallic- 2000 trans am
weld in are better, but bolt in is better than nothing. you can always bolt them in for now and get them welded later on.
bigger rear bars help, but not everyone needs them. sit down and look at your plan for the car before you start buying parts. do you have trouble hooking now? any wheel hop? how much power do you plan on making? is it street driven? do you care about handling at all?
02-08-2010, 12:39 PM #3
I don't know about drag apps. But a stiffer sway bar will help reduce or elminate(sp) body roll and could prove to greatly improve or reduce cornering.. Sometimes too stiff a bar and the rear becomes harder to keep under control powering out of corners. Especially on the street where the surfaces can vary greatly...
02-08-2010, 12:49 PM #4
If you have stock lower control arms and panhard bar you should consider upgrading to either boxed or tubular pieces -- before a sway bar upgrade -- imo. I went with all UMI stuff on our car and am quite pleased with the fit and quality of their stuff.
02-09-2010, 07:05 AM #5
- Nov 2009
- Kansas
Ya iv heard alot of good things about UMI products. As of now its my DD and ill probably just add headers and ORY next (with all other bolt ons). But later i plan on really tearing into it and making it my weekend drag car and pretty much do away with makeing it my DD. So ill just do some more research untill then, ill have to see how it hooks up this year at the track with the M/Ts.
Thanks
Rear Sway Bar Mounting Question
By rbruner10 in forum Suspension and HandlingReplies: 11Last Post: 02-26-2011, 07:05 PM -
rear sway bar help
By Ramairgod84 in forum Suspension and HandlingReplies: 3Last Post: 04-23-2010, 07:39 AM -
MAf,AGX rear shocks, Strano sway bars,1LE sway bar
By AFASTYZFR1 in forum Parts For Sale / TradeReplies: 3Last Post: 09-21-2008, 01:54 PM -
WTB BMR rear sway bar
By QtrWhore in forum Parts Wanted / TradeReplies: 0Last Post: 08-11-2008, 06:35 AM -
Stock front sway bar rear sway bar........
By pewterzron in forum Parts For Sale / TradeReplies: 5Last Post: 06-27-2008, 03:42 PM
