Results 1 to 10 of 10
Thread: posi vs lsd?
    Don't Listen to Me NE98LS1's Avatar
    Nebraska
    posi vs lsd?
    what is the difference between posi and an lsd? i don't really understand either, and not sure what my 98 TA wouldve come with?
    Lost in Texas
    Custom Slate Blue
    99 B4C
    true posi has no slip whatsoever, both axles pull equally all the time. LS allows one to turn a small amount before locking them both together into posi style. It makes for smooth turns. With a true posi you have one wheel hopping in turns due to the different speeds they need to travel during the turn.
    Nebraska
    what do our cars have? or is that an option code i'd have to check out?
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    our cars have LSD's limited slip differentials, i'm not sure of the code, i have it somewhere
    ga
    blue
    1998 trans am
    A posi and a lsd are the same thing.
    Your 98 T/A came with a LSD.
    You have three types of differentials, basicly...
    1. Open differential = non performance applications, one side or the other transfer torque(spins)
    2. Limited slip differential. = Posi is a slang word for limited slip (lsd), the words are interchangable. A limited slip will be one of two types, clutch or cone, either style works fine, the clutch style is easier to rebuild. A limited slip needs a friction modifier added to the lube to prevent chatter/clunking. A limited slip will spin both sides equally until something evercomes the clutches/cones, like taking a sharp corner. If it is working properly, you will never know it is slipping, thats the way it was designed.
    3. Locker = A locking differential will transfer torque to both wheels through mechanical design, the detroit locker will unlock during sharp corners, it ratchets and clunks very loud and noticable. Off road enthusiests use air lockers, which are on demand differentials. Just turn them on when off road and get torque to both wheels.
    The Masterpiece Qwk94Z28's Avatar
    michigan
    SOM
    1998 Z28-408 l92 stroker
    Z driver one said it in simple terms, 1969..... said it almost out of a book lol.
    depending on what your cars main use is, prolly daily street ect. i'd go lsd
    ga
    blue
    1998 trans am
    NE98LS1 asked what is the difference between posi and an lsd?
    There is no difference, they are the same thing.
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    I'm with him ^....LSD = posi
    Lost in Texas
    Custom Slate Blue
    99 B4C
    In my opinion a "locker" is the same as a limited slip and a posi in locked together all the time. Why would it be called a locker if it was always locked? The name implies that it isn't always locked and it locks. Either way, his question was answered and terminology isn't exactly the important thing. Most old school guys call it a posi anyways, back in the day you had single trac and posi, no limited slip
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by z_driver1
    that would be callled a spool. not a posi. a spool locks both axles together basically making it one solid axle all the way across.
    locker, posi, LSD (not the drug), posi-traction = all the same. locked together drive straight. unlocks so the wheel on the inside of the turn will free spin.
  1. aburn posi vs eaton posi units
    By TOOSHORT2000TA in forum Drivetrain
    Last Post: 04-05-2009, 06:01 PM
  2. Posi my ass!
    By Smkn_TA in forum Drivetrain
    Last Post: 12-11-2007, 06:13 AM
  3. Got posi???
    Last Post: 10-18-2007, 09:56 PM
  4. 3.42 to 3.73 posi..
    By blackhawk01 in forum Drivetrain
    Last Post: 05-15-2007, 05:08 PM
  5. Do the '04-'06's have posi?????
    By rrrcustom in forum GTO
    Last Post: 01-08-2007, 06:11 PM
