Results 1 to 11 of 11
    New Orleans
    2000 Chevrolet Camaro Z28
    Another Cam Question
    I am looking at getting ...
    GM Performance 12480033 - GM Performance Gen 3 Hot Cam Kits
    Cam and Valvetrain, Hydraulic Roller, Duration at .050 in. 219/228, Lift .525/.525, Chevy, 5.7L, LS1
    Part Number: NAL-12480033
    Transaction$489.95
    and...
    Harland Sharp SLS17 - Harland Sharp Shaft Mount Roller Rockers
    Rocker Arms, Pedestal Mount, 1.7 Ratio, Aluminum, Roller Rockers, Chevy, 4.8/5.3/5.7/6.0L, Set
    Part Number: CSP-SLS17
    Transaction$379.95
    should I stick with 1.7 ratio or get the 1.8s? what length push rods do I need? Is this a good street setup? I'm also wondering about exhaust,shorties are in my budget but which ones? and everything is completely stock except for the straight pipes,no muffler or cats and slp lid. thanks for your help.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    If your tranny is an A4 I'd go with a 3400 stall and tranny rework (sunshell, better disks, drill mod, TM delete and shift kit and cooler) before a cam.
    Stall alone netted me almost .5 seconds off in the quarter.
    Also do an LS6 intake before the cam.
    Gotta have the supporting mods 1st.
    Do you have SFC's? That should be 1st before all else. You wanna be able to close the doors down the road don't you? And this will keep the T-tops from leaking as body flex on these cars is pretty wicked.
    I still have a stock cam and I go mid 12's. One of my friends is knocking on 11's with a stock cam.
    Jun 2009
    coon rapids, MN
    2000TA
    if you are running stock heads stick with the stock rocker arms.check out TSP web sit for a cam kit.do what 67CamroRSSS said.look at bmr torque arm adj.,and rear control arms.
    New Orleans
    thanks guys, the only reason i was going for the cam so soon was that I have to replace my lifters(making noise) so i just figured I'd go ahead and change the cam. I'm actually a tech at a Gm dealership so I'll be doing all the work but I don't know squat about building performance cars so ill be asking for plenty of advice. The initial investment for my mods is going to be $800-$1000... What should be done first?
    15 sec. Oh yeah, its fast UTVols98's Avatar
    Forest Lake, MN
    maroon
    2000 Z28
    what made you pick that cam?
    don't go with 1.8 rockers... the cams are set up for the stock ratio...
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    If youre spending the money on a new cam, then why dont you go with something a little bit more aggressive? I guarantee you will be happier with something more on the lines of a Tr224 or Tsp 224 than that hot cam. If you wanted a little bit more than that a Tsp 228 would be pretty well suited to what you want. Just my .02
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    Jun 2009
    coon rapids, MN
    2000TA
    long tube headers,a good ORY and a 3' pipe and a magnumflow muffler.tail pipes slow you down.
    Member marksls1ta's Avatar
    pikeville, kentucky
    1998 trans am
    let me know if we can help on the parts. PM me if you want some pricing
    Thanks,
    Mark
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    Do not do 1.8 rockers and a hotcam.
    Considering you have $1000 to spend, get a stall (3000-3500), shift kit and trans cooler.
    Youll also rear need tires.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    New Orleans
    thanks guys, i really appreciate your help. I had someone from work tell me to go with a 373 gear what do you think? i also have the zexel torsen differential, is it any good?
  1. speedometer question + top speed question
    By Krazy351w in forum General Help
    Last Post: 06-21-2007, 05:51 PM
  2. HPIII question (not the same old question)
    By slims00ls1z28 in forum Computer & Tuning
    Last Post: 06-01-2007, 04:55 PM
  3. 97 Bird Headlight question also engine noise question
    By Zapper2003 in forum General Help
    Last Post: 12-13-2006, 03:03 AM
  4. Speedometer question, RPO question
    By acrylicophobia in forum Firebird / WS6
    Last Post: 11-02-2006, 07:08 AM
  5. Sex Question spinoff- PORN QUESTION
    By egaian in forum Almost Anything Goes
    Last Post: 07-26-2006, 03:07 PM
