    Junior Member YellowTA's Avatar
    2002 WS6 TransAm
    Suspension Advice
    ok, first off, I don't take my car to the track, nor do I race it any other fashion. In reading some of the suspension forum info., I haven't truly found an answer. I currently have a set of Eibach sportlines I am going to put on (yes, I'm going to need & get the adj. panhard rod). Are there any recommendations to shocks that I need to change before doing the drop, or are the factory shocks sufficient?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Most will recommend the konis if you have the money. Very good quality and adjustable too.
    2002 WS6 TransAm
    that's part of the problem...I don't want to go to something that is a waste of money, but I can't afford to buy the mansion on the hill either. a nice, happy medium would suited better for my pocketbook....
    Feb 2006
    Orange County, NY
    always dirty
    I would do bilstens then. That is what I will go with when the time comes.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I've heard the same thing. Koni's -1st, Bilstein - 2nd
    2002 WS6 TransAm
    ok, i'll do some checking and see what a set runs. Would be pointless to put the springs on, then do the shocks, so i'll wait & do it all in one shot, would be better I think.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Just an FYI.
    Those Sportlines are not going to ride well regardless of what shocks you install. Their spring rate is insufficient (basicaly stock) compared to the amont of drop the have.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    2002 WS6 TransAm
    Quote Originally Posted by 9T8W66 View Post
    Just an FYI.
    right, I've read some of the reviews of the sportlines, BUT would it still not be better to upgrade the shocks compared to stockers??
    `98 Formula M6 HdTp
    Quote Originally Posted by YellowTA View Post
    Yes definetely upgrade the shocks, I just wanted to worn you if you looking for a good ride with those springs your likely to be dissapointed.
  1. Advice on planned suspension upgrade
    By bberretta in forum Suspension and Handling
    Last Post: 02-13-2012, 04:10 PM
  2. advice on suspension
    By bpopham22 in forum Suspension and Handling
    Last Post: 03-06-2010, 06:21 AM
  3. Suspension Upgrade need advice!
    By Octavain in forum Suspension and Handling
    Last Post: 03-02-2010, 01:40 AM
  4. Next suspension mod advice
    By grandkodiak in forum Suspension and Handling
    Last Post: 06-01-2009, 08:41 AM
  5. Suspension advice
    By noblesramair in forum Suspension and Handling
    Last Post: 11-05-2005, 03:06 PM
