Results 1 to 19 of 19
    Valve cover gaskets -- reusable?
    I started my LT install this evening and just pulled my coil packs -- exposing my not so nice looking valve covers. As I can not leave well enough alone, I'll probably pop off the covers to clean them up and maybe even polish them. Are the stock gaskets reusable or are new ones almost always required?
    New Jersey
    Torrid Red
    2004 GTO
    The "rule of thumb" I was always taught was to never reuse a gasket. But it is possible to reuse them without any problem. If they dont appear to be brittle it shouldnt be an issue. My opinion, if they have never been changed before it cant hurt to throw some new ones in there.
    Quote Originally Posted by Goat04 View Post
    I agree -- but some of these neoprene gaskets (or whatever they are) seem to hold their seal really well. I just figured it would be best to ask the opinion of those that have been there before.
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    If you can get them to fit by all means when I took mine off they had swelled an inch too big so I ended up getting new ones anyway.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    The stock valve cover gaskets are designed to be fully reuseable. So as long as they are in good condition, there is no need to replace them. You just have to use your discression.
    1998 Trans Am WS6 SGM
    Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
    these gaskets are a lot different than the stuff on the older cars. GM got it right with the gaskets on the LS motors. Think o-ring. I've had my covers off a couple of times and kept the same gaskets in there.....same goes for the intake and throttle body.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Agreed with Orion. Ive taken my valve covers off more times then I can remember and reused them. Obviously inspect them for major breaks, but chances are they will be perfectly fine.
    Build in progress...
    Wisconsin
    2001 Camaro SS M6
    They are not meant to be reused but can be and it has been done before. Here is a bit of info from the GM designers/Performance builders:
    "This brings up a good point: don't reuse any Gen III V-8 gaskets because they are all of the compression-carrier design. This means the aluminum surface of the gasket takes the torquing load to control how much compression the embedded silicon sealing surfaces experience. This maximizes sealing control and minimizes the need for re-torquing to maintain the clamping load-but they are one-use items."
    This straight from GM's/Horses mouth. 99% of the time, reusing them would be fine. I have seen people reuse them with no problems but everyone should know the FACTS
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    Pittsburgh
    2008 Hummer H3
    Imho Jeff for all the more they cost I'd just replace them, takes the guess work right out of the project. Just my .02 ..
    I went down to the dealership a few minutes ago and grabbed a set of new gaskets. I choked when the tab came to almost $45.00, but now I have the new ones to install and possibly a spare set if I ever bung one up.
    Thanks for all the input!
    i've always reused mine... never had any sealment issues...
    From what I understand, your motors do not last long enough for a leak to form.
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Ive reused mine on both my cars and both have been fine. The 98 just turned 196,000 a few days ago and i did my headers about 3 weeks ago and they are fine, no leaks.
    BTW i wanna see pics of your engine cleaning up, im sure you wont leave it the way it is by seeing the work on your rear
    Already started taking pics. Probably will not post a new thread on the header swap as Chuckie did a real nice job in his and it was stickied.
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Just do it for the pics I would like to see what you do with your valve covers and coils
    i can't argue that... however my ls6 is hanging in like a champ!!!
    Wisconsin
    2001 Camaro SS M6
    OH SNAP!
    him and Ed have the same issue......their cars leak rods and pistons.
    Wisconsin
    2001 Camaro SS M6
  1. coil cover idea... sbc valve cover
    By BLK2KSS in forum Appearance Section
    Last Post: 11-14-2012, 07:19 AM
  2. Help: valve cover too low
    By timowen1 in forum General Help
    Last Post: 10-15-2010, 08:54 AM
  3. Valve cover gaskets, Valve Springs, Timing Gasket
    By Dewman in forum Parts For Sale / Trade
    Last Post: 01-22-2010, 08:14 PM
  4. Valve Cover Breather/ PCV Valve
    By lonewolf37 in forum General Help
    Last Post: 10-26-2007, 02:24 AM
  5. WTB Valve Cover
    By fright88 in forum Parts Wanted / Trade
    Last Post: 11-21-2006, 06:46 PM
