Results 1 to 15 of 15
Thread: Whine?
    Member lsgunner28's Avatar
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    Whine?
    Anyone else get a radio whine while driving? I ran new wires, still there.
    How can I fix it?
    thx
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by lsgunner28 View Post
    How can I fix it?
    thx
    Its probably just picking up electrical "noise" from the alternator.
    They make in-line noise filters that you can install, any car stereo retailer (Best Buy, ect) should have them for cheap.
    1998 Trans Am WS6 SGM
    Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
    Wisconsin
    2001 Camaro SS M6
    Quote Originally Posted by Wesman View Post
    But I see in your sig that it says SGM after your car, does that mean Sergeant Major by any chance
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    NJ
    SGM
    1998 Trans Am WS6
    No lol....Sport Gold Metallic!!
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    More than likely what Wesman said.
    Is your radio stock? aftermarket? Are you running any amplifiers?
    If aftermarket with amps, are you running your power cable down the same side of the car as your RCA jacks? That could be picking up noise also.
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    Its aftermarket radio with a small amp.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Check your grounds. Also what 35th said. Another thing is make sure you didnt pinch or put a screw through an rca when replacing panels if everything else checks out.
    Member Sas's Avatar
    Loveland/Ft. Collins, CO
    Blue
    2001 Formula Firehawk
    Sounds like you need some shielded RCA's, or you have a ground wire run next to your RCA wire.
    Pittsburgh
    2008 Hummer H3
    Could even be not enough of a ground. Is your ground out from the amp the same gauge as your power (12v) in? If not good idea to get them matched up. Sometimes mismatched wiring to the amp and so forth can cause this. Too much return resistance if the ground is smaller than the hot.. Also what Wes said is always a good idea on an after market HU unless it has a noise supressor built in.. Good of gold RCA's are a must as well..
    long and strong Willfully Armed's Avatar
    Olathe, KS
    01 WS6 (stock)
    your amp ground should be the same size, or larger than your power. makes perfect sense if you understand electictricity.
    Your ground should be as short as possible. less than a foot.
    Could be a junk amp as well.
    Whats your setup?
    Pittsburgh
    2008 Hummer H3
    Wink
    Quote Originally Posted by Willfully Armed View Post
    Whats your setup?
    Oh I think I understand electricity (See sig link)
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    it did it when i bought the car, it had a 300w amp running pioneer speakers, diff head unit, and 10 disc cd changer. i also hooked up a 700w amp and 12" sub, still does it but didnt make it any better or worse. it has to start at the alternator b/c it changes pitch when i rev the car.
    Member Sas's Avatar
    Blue
    Sounds like you need to rewire things to get rid of the whine, the most common cause for it is people running all the wires down one side of the car, rather then running RCAs on one side, and ground, power and remote down the other side.
    Feb 2008
    Russellville, MO
    It could also be cheap ass RCAs too. Try to make sure that none of your wiring is next to any wiring for your car, it's hard to do. I had the same problem when I first put a system in my car.
    Olathe, KS
    01 WS6 (stock)
    what kind of amp and sub.
    as for wiring, my wires run down the passenger side, no whine.
    It does not mean the alternator if the noise correlates with rpm.
    bad plug, wire, coil, coil ground. All of these could cause noise, all would correlate with rpm.
  1. Whine
    By Orp0408 in forum Drivetrain
    Last Post: 08-13-2011, 01:30 PM
  2. Question: Whine Question...
    By cammed goat in forum Manual Transmission
    Last Post: 02-16-2010, 03:00 PM
  3. Whine from 0-15 MPH
    By eddielb in forum Drivetrain
    Last Post: 02-11-2009, 02:15 AM
  4. Rear End Whine
    By Blackout01 in forum Drivetrain
    Last Post: 07-21-2007, 08:35 AM
  5. WS6 Whine
    By noelp3 in forum Firebird / WS6
    Last Post: 11-24-2006, 01:36 AM
