Results 1 to 3 of 3
    San Diego
    1998 Pontiac
    Head Unit Question
    I am pretty good with stereos and I love the look of this head unit. I am not worried about power out put as I have 3 sets of JL audio components with a separate 6 channel amp, 2 WX 10s in the trunk on either side with a 300/2 amp for them. My question is has anyone seen this head unit and do you think it will fit nicely in the factory location?
    http://www.woofersetc.com/index.cfm?...roduct_ID=7663
    I am on deployment in the navy and don't have the exact dimensions of our bay for the head unit. It looks like it would drop right in minus the little angle cuts on the bottom but nothing I cant modify the cover to fit. I considered moving the ac controls and doing a car pc but would love this head unit instead.
    Very Respectfully,
    Seth
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    I looked at these not that long ago online. It's a single din fitment with an over sized face right?
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    It's a single DIN that is oversized while ours are DIN.5 (DIN + 50%). You'll end up fabbing up the bezel to make it look right. Basically it'll work similarly to a Double DIN install. You'll need custom brackets. Most likely you can get a Single DIN kit and use the brackets and the filler panel- just cut into the panel and you can make it look good. I haven't actually worked with an oversized DIN, so I can't tell exactly what to do.
  1. Procharger Head Unit Question
    By 35th-ANV-SS in forum Forced Induction
    Last Post: 09-25-2013, 01:42 PM
  2. New Pioneer Head Unit Question!
    By 10erg01 in forum Stereo and Electronics
    Last Post: 12-05-2010, 03:47 PM
  3. 2002 Monsoon WS6 head unit question
    By jrc1122 in forum Stereo and Electronics
    Last Post: 07-07-2007, 11:11 PM
  4. Stock Head Unit System or install custom head unit?
    By ibh182 in forum Stereo and Electronics
    Last Post: 06-16-2007, 09:43 AM
  5. Sony Xplod Head Unit Question
    By Duffster in forum Stereo and Electronics
    Last Post: 09-19-2005, 06:33 PM
