Thread: Junkyard PCM--nothin..
01-25-2010, 08:04 PM #1
What's up guys--haven't really spent any time in this corner of LS1 since I had to trade the t/a... my grandfather has a 2000 Cadillac Deville and the PCM has gone south in it. Car still runs fine, but doesn't recognize any sensors. Meaning it Gives you every warning...low coolant, security, etc every time its on; plus gas guage doesn't work. Dealer told him he needed new PCM, so my uncle got one from a same year deville; supposedly same type car ( I just moved here and wasn't around for that) and swapped the PCMs. Said the car wouldn't do anything with the others PCM installed. Wouldn't start; nothing. Reinstalled original PCM and car functioned as it had before the swap. I would like to know if there is an obvious reason for the car not to function with the replacement PCM--some sort of initialization or something we don't know to do--aside from the possibility of it just bein a faulty scrap yard PCM. I have no experience with PCMs so I wouldn't know the simplest answer--plz educate me guys!! (where you at Frost
01-26-2010, 01:50 PM #2LSwut
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
(from GM - paraphrased)
I'm not sure but I think you need a Tech II to do this.Double check everything is hooked up and all the fuses are there/not blown
And then you have to reset everything... Transaxle fluid/oil life (to what it was before)
Relearn on Theft Deterrent Learn, CKP System Variation Learn, TP sensor Learn and IAC Valve Learn
01-26-2010, 08:30 PM #3
huh... thanks! any other ideas anyone?
01-26-2010, 09:03 PM #4LSwut
- Jun 2009
- Saint Louis, MO
Just have a dealership or someone familiar with GM PCMs reprogram everything
01-27-2010, 09:28 AM #5
will do--thanks for the quick response!
nothin good in the news around here...
By jiveass in forum Almost Anything GoesReplies: 25Last Post: 06-17-2011, 07:35 PM -
Hate to bring up past angst, but here goes nothin!
By tommy303 in forum Rocky Mountain MembersReplies: 6Last Post: 03-14-2008, 07:31 PM -
BC junkyard dogs?
By RyanoLS1on in forum Wheels and TiresReplies: 2Last Post: 10-06-2006, 06:47 AM -
Hilltop Junkyard
By 02BLKSS in forum Western MembersReplies: 2Last Post: 04-29-2006, 07:56 PM -
Junkyard Rear End
By SleeperZ28 in forum DrivetrainReplies: 3Last Post: 11-14-2005, 08:55 AM
