Thread: Backup/reverse light problem
01-19-2010, 08:03 PM #1Junior Member
- Dec 2009
- NM
Red- 1999 Trans Am
Short background story, motor spun a bearing, just had a new one put in. After getting the new one put back in now only one reverse light works. I thought at first it was a burned out bulb, so I swapped it out with a new one, and no go. Then I noticed the one that doesn't light up when in reverse, does light up when I arm or disarm the car.
Where would those wires be crossed? Thanks
01-20-2010, 03:09 AM #2Senior Member
- Apr 2008
- Madison, WI
check the connection at the socket. Other than that its a very simple circuit with a fuse, a switch in the trans, and one wire back to a splice, then to the bulbs. Both bulbs even share the same ground
01-20-2010, 04:02 AM #3Senior Member
- Nov 2006
- Indianapolis
Just checked my car. When I use the factory remote, the reverse lights do not flash ever.
To start figuring this one out, I would first turn on the parking lights and see exactly which lights are working and which are not. Then, turn the hazards on and see if all four lamps flash in the taillights along with the taillights still working normally. There should still be no reverse lights on. Then turn it all lights off, key on, put it in reverse, and see if only the reverse lights come on and not a taillight. It's possible the socket got jambed in the wrong place and you are just now noticing a problem. (Like the reverse socket put in the taillamp housing, I've seen some really jacked-up screwups in my career.)
Hard to daignose these things from hundreds of miles away, but like Cutlass said, it really is a pretty basic circuit, I don't see how an engine install would jack up the wiring itself. Unless some hack worked on it, chopping wire harnesses along the way and not putting things back together correctly.
Good luck, hope it's something simple!
01-20-2010, 11:20 AM #4Junior Member
- Dec 2009
- NM
Red- 1999 Trans Am
I didn't do a thorough test, but I went out and tested to make sure none of the tail lights came on in reverse, and none did, so it doesn't look like the plugs are swapped. As far as I can tell all of the other lights operate normally. I'll do a thorough test tonight, after it gets a little bit darker.
They did put on a new wiring harness with the motor though, not sure if that harness touches any of the wiring for the lights?
01-20-2010, 11:47 AM #5
01-20-2010, 12:40 PM #6Junior Member
- Dec 2009
- NM
Red- 1999 Trans Am
01-21-2010, 02:11 AM #7Senior Member
- Nov 2006
- Indianapolis
If it worked fine before they did anything, and they added a wiring harness, you should take it back to them and explain the problem.
Why is just one reverse light doing this?
By Capt Pie in forum Firebird / WS6Replies: 6Last Post: 02-24-2015, 10:38 PM -
Reverse Light Switch
By GatorSS in forum General HelpReplies: 3Last Post: 01-07-2015, 07:29 AM -
Rear Backup Camera - connecting to reverse lamp
By EnemyAce in forum Stereo and ElectronicsReplies: 2Last Post: 04-17-2010, 01:22 PM -
Backup Light Fuse
By JEB in forum General HelpReplies: 3Last Post: 02-10-2006, 12:12 PM -
Problem in reverse
By Zeroskater1028 in forum Manual TransmissionReplies: 9Last Post: 11-21-2005, 04:30 PM
