Results 1 to 20 of 24
    Member excrider121's Avatar
    Sep 2008
    Dark Steel Metalic
    98 T/A
    Fluctuating Voltage
    So, driving down the road, my lights flash...all of them. The headlight, the turn signals, the lights in the instrument panel and even the CD player flicker. The voltage guage is fluctuating as well. It will bounce between 13-14. The flickering is at the same rate regardless of what I'm doing, driving fast, driving slow, accelerating or braking. Turning on various other things (heater, ac, stereo) also have no effect on this.
    Any ideas?
    Feb 2006
    2002 WS6
    alternator is going south.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    yep alternator
    2000 Camaro B4C
    had the same problem, new alternator
    2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
    yep...voltage regulator in the alternator is probably taking a dump. You can probably put a volt meter across the battery with the car running and watch it fluctuate.
    NC
    SOM
    1998 T.A.
    I just had mine rebuilt at a rewinding shop for less than half of what the chain stores wanted and they are just going to sell you a rebuilt one any phucking way.....
    Sep 2008
    Dark Steel Metalic
    98 T/A
    That's what i was thinking, but I wanted to be sure.
    Thanks
    Orlando, FL
    Mean Black
    I have to agree on this one. Change your alternator 1st.
    Sep 2008
    Dark Steel Metalic
    98 T/A
    Ill wait until it quits charging. Right now it's keeping the battery above 13v.
    400rwhp::370rwtq Lucky 13's Avatar
    Little Elm, TX
    2002 T/A WS.6 -- ASC#12
    no chance of a bad ground here???
    Sep 2008
    Dark Steel Metalic
    98 T/A
    I had planned on adding a bigger ground lead from the negative terminal to the frame just to see...
    I'll try to find time this weekend to get it done.
    Junior Member silver2002ws6's Avatar
    big spring tx
    2002 trans am
    i had the same problem but i just put a new alt like a month ago
    Sep 2008
    Dark Steel Metalic
    98 T/A
    I'm guessing it fixed the problem?
    you might also want to take a wire brush and clean the terminals on your battery... corrosion can build up on them and cause these problems as well... but more than likely it's your alternator like every one else said...
    Jun 2006
    New york
    How old is the alt.,Some time the brushes wear down causing problems.Cheap fix,brushes are cheap.You might try taping on the alt. when it's running see if that helps,or wiggling the connections on the alt. plastic plug,may be corosin there.
    Senior Member kool-aide's Avatar
    Deltona, FL
    Sebring Silver Metalic
    2002 Camaro Z28
    Quote Originally Posted by excrider121 View Post
    I would not do that. If it turns out the regulator is going out on the alternator. You can do serious damage. Once that sucker goes out you can blow up a battery. No joke. I had mine go out while i was driving it. It started putting out way too much current and started to kill the battery. Later I found out if you let this go on you can possibly blow a battery, not good.
    For me when the regulator went out all kinds of things started happening. ABS in-op, all kinds of dash lights coming on. The dash volt meter would dance like a crack head. It was pretty scary, lol... It was like Christmas, a pin ball, and ghost all fighting it out.
    good luck, and keep an eye on it.
    Sep 2008
    Dark Steel Metalic
    98 T/A
    Quote Originally Posted by buzz View Post
    Alt is probably the factory alternator (12 y/o). I'll replace the alternator before i repair it. Terminals are clean, and I don't care about a never start battery.
    Jun 2006
    New york
    Replacing is the best thing! Probably easier than trying to trouble shooting it.
    Sep 2008
    Dark Steel Metalic
    98 T/A
    You're right. But pockets are very shallow for a student.
    NC
    SOM
    1998 T.A.
    That is why you should take it to a rewinding shop...........
  1. Temp gauge fluctuating
    By redbird555 in forum General Help
    Last Post: 06-03-2010, 05:14 PM
  2. Help: torque fluctuating
    By Camarobert in forum Camaro / SS
    Last Post: 04-13-2009, 04:34 AM
  3. temperature gauge fluctuating
    By jodmartyr in forum Stereo and Electronics
    Last Post: 04-20-2007, 10:06 AM
  4. temperature gauge fluctuating
    By jodmartyr in forum Firebird / WS6
    Last Post: 04-18-2007, 06:19 PM
  5. Fluctuating Voltage???
    By kevakasper in forum General Help
    Last Post: 10-10-2006, 10:17 AM
