Thread: water in oil
    georgia
    2002 trans am
    water in oil
    i have an ls1 that seems to have a little water in the oil. can anyone give me any ideas where to start as far as the cause may be to the problem.
    Feb 2006
    2002 WS6
    need a better idea as to how much, how long has the car sat and so forth. how you discovered this as well, but most likely its a head gasket. Check the rad for oil in the water.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Quote Originally Posted by Orcus79 View Post
    Yepp I agree, could be something simnple like condensation or a little worse "head gasket"...
    J
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by jessews6 View Post
    Get a cooling system pressure tester (they rent them as many auto parts store, such as Advance) and pressure test the system. That way you know where to start.
    1998 Trans Am WS6 SGM
    Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
    georgia
    2002 trans am
    hey thanks guys ill try testing the cooling system and see how that goes. i notest the problem when i pulled the dip stick and seen that it was a little milky at the very tip of the dip stick. i also just got the oil changed about 5 or 6 days ago. i use the car as a day to day driver. if yall have any more ideas please let me know.
    Dec 2009
    Conroe, TX
    Blue
    2001 Trans AM
    Let us know as soon as you find out! But it doesn't sound good! My guess is the head gasket!
    check your coolant and see what it looks like.....has the car been overheated or anything? Reason I ask is I rarely ever here of someone popping a head gasket on these things. Matter of fact I would probably exhaust ever other possibility before thinking head gasket.
    georgia
    2002 trans am
    i have had the car for over a year and no over heating.
    NC
    SOM
    1998 T.A.
    Figure it out quick because coolant in the oil will ruin bearings fast.......
  1. Help: why do I have water in my car
    By WILDKARDBOYZ in forum Appearance Section
    Last Post: 02-20-2012, 07:38 PM
  2. Replies: 15
    Last Post: 05-15-2011, 09:28 PM
  3. When to water?
    By clg82 in forum Almost Anything Goes
    Last Post: 05-21-2009, 06:32 PM
  4. Do electric water pumps pump enough water for daily use?
    By xinthenight in forum External Engine
    Last Post: 08-02-2007, 09:04 PM
  5. Water on Oil Cap
    By heydude in forum Internal Engine
    Last Post: 03-13-2006, 03:56 PM
