Results 1 to 13 of 13
Thread: Magna Charger
    Oct 2009
    blue
    2000 Firehawk
    Magna Charger
    Hello guys, i just picked up a 2003 Z06 with a Magna Charger, Meth injection and a cam. The car produces 558rwhp on a speed density tune. At 2200rpm the car stumbles, you can accelerate through 2200 or cruise at 2100 or 2300 with no problems, but stating at 2200 doesn't work. The guy I bought the car from claimed it was what people claim as the Magnuson stumble. Any of you guys hear about this. Thanks.
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    ? Sounds like it needs a better tune
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Where did you buy it from? Problem with speed density is if the conditions are different then when it was tuned your screwed-like mountain driving for instance.
    Oct 2009
    blue
    2000 Firehawk
    Yes, the car was tuned in Mass. and I have the car down in Texas, so that could easily be my problem. Thanks.
    Bay Area
    my highbeams
    Quote Originally Posted by lyle8206 View Post
    Show it by posting some pics of the ride
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    It IS the magnusson stumble... It happens between 1800-2200 RPMs from what I have seen. The lower intake must cause some turbulence around that area. When logging, one bank of fueling wanders lean while the other wanders rich. If the VE is fully tuned, having LTFTs disabled usually helps a bit. Some are worse than others about it. The higher your blower is pullied, the generally more pronounced it is. I have seen it on everyone of them. There is no tuning around something like that.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    That's an internet myth that NEEDS to die.
    The car has a MAP sensor. MAP sensors measure the pressure of the atmosphere around them. Speed density is based around this sensor. I can tune a car here and drive it to the mountains and everything is still fine because I take the time to really calibrate.
    Bay Area
    my highbeams
    Our tuners are lazy
    Oct 2009
    blue
    2000 Firehawk
    Thanks Steve, the guy I bought the car from told me about the Magnuson stumble but I could not find anything about it online. You put my mind at ease.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    I've never seen much discussion about it (though there is a little in one thread over at HPT) but it's real... One bank of fueling completely wanders off in that area. We don't have left/right bank control either, so there really is nothing that can be done as far as tuning.
    Dec 2008
    Anderson, SC
    Metallic Red/Charcoal
    2000 Z28
    Mine doesn't do it, maybe lucky, speed density setup, tuned by MTI in Marietta, GA. 770-919-7774. I believe the guys name is Reece. After install,hauled it down there on role back left it for about 10 days. That was a year ago, still no problems.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Do the MAP sensors on our car recalibrate for the atmospheric pressure in real time??
    I know on some older cars with MAP sensors, if you started the car in a low elevation and then drove up a mountain, the car would run like crap because it wouldn't adjust for the new baro reading until the next key cycle.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by Night Move View Post
    I bet big money it happens, it just doesn't cause any rough feeling in many cars. Something happens and the fuel trims for one bank wander off in one direction and the other goes the other way. In fact, 5 out of 6 cars with these blowers experience nothing odd there that can be felt, but it is definitely there.
    Quote Originally Posted by Wesman View Post
    Never seen or heard of a problem such as this with the GENIII cars.
  1. Magna charger for F body!!
    By rapter34 in forum Forced Induction
    Last Post: 02-13-2009, 03:19 PM
  2. LS1 Magna Charger TVS Supercharger Install - Magni
    Last Post: 12-08-2008, 07:20 PM
  3. installing new magna catback
    By jd1666 in forum External Engine
    Last Post: 07-30-2008, 02:24 PM
  4. GMMG or Magna Flow??
    By jd2002ss in forum External Engine
    Last Post: 06-30-2008, 05:11 AM
  5. Magna Charger - Magna Charged
    Last Post: 11-26-2007, 08:34 PM
