01-14-2010, 06:17 PM #1
Driver's Side Steering Linkage Shaft Install
What up LS1's......OK gentleman my driver's side (bottom) steering linkage for whatever reason will not hook up unto its intended location.......I mean is this suppose to be difficult to set back on?????? Are you suppose to install the bolt a ways and then try???? I don't understand why it will not connect......and there is no obstructions in the way preventing it from hooking up. Additionally, does this bottom linkage seat ALL THE WAY DOWN on the hook up location??? When you look into the shaft there is an opening that looks like it SHOULD fit right over....but mine isn't budging........... It is driving me crazy yall!!!
Thanks in advance.......
01-14-2010, 06:19 PM #2
ORION where you at my brotha?????? I'm patiently awaiting your award winning expertise..
01-15-2010, 11:10 AM #3O U 8 1 2
- Nov 1999
- over here...
there is a bolt you'll have to losen on the top part of the linkage from above the car... that wil allow you to move it in to position... that is if we're talking about the same part (the actual shaft rom your steering wheel to the linkage)...
01-15-2010, 03:44 PM #4
01-15-2010, 05:54 PM #5
is this your stock rack or a replacement rack? and are you talking about the shaft fitting onto the rack? I've never had my rack out but the ones I have had out can be a pain in the ass to deal with. I would go with Spaz's advise since he's had his out. If it's a replacement rack it's very common for people to get the wrong rack.
01-15-2010, 06:14 PM #6
It's the OEM Rack. I find it odd that the bottom linkage fitting will not hook up. I'll take Spaz's advice and see if this yields any results. This linkage is holding up the final pieces of my overhaul install!!!! (just have the Y-pipe, Sway Bar left (also need to bleed the brakes-which I'll be starting momentarily).......WHAT a long road..........
01-15-2010, 07:26 PM #7
01-16-2010, 03:38 AM #8Senior Member
- Apr 2008
- Madison, WI
A hammer or pry bar may help you get it back on.
01-16-2010, 06:37 AM #9O U 8 1 2
- Nov 1999
- over here...
ok... did you replace the steering rack??? if you did you might have got the wrong rack... there are 2 (i think) different rack for our cars... the code for the right rack will be on your drivers side door sticker... other than that i'd use a rubber hammer to tap it in place (you won't hurt anything)...
01-16-2010, 08:22 PM #10
OK.......Got it on!!!!!! Late last night things finally hooked up. I will say this guys, attention to detail is vital when re-installing parts on our vehicles especially if your doing it on your own & it's your first time. (BTW I was re-installing the OEM Shaft linkage) I would like to extend a very special thanks to Cutlass, Spaz & Orion for the advice. I appreciate it guys....... Ok Sway Bar, Strut Tow Brace and Y-pipe is all that's left!!!
01-16-2010, 08:25 PM #11
01-16-2010, 08:27 PM #12
Help: Steering linkage bolt catching bad on new header
By Johnner in forum External EngineReplies: 3Last Post: 08-19-2014, 10:21 AM -
ls1 steering linkage
By Scott5586 in forum Parts Wanted / TradeReplies: 3Last Post: 12-20-2007, 04:25 PM -
driver side window install (99 camaro)
By SPDemon81 in forum General HelpReplies: 3Last Post: 09-25-2007, 10:57 PM -
Cant get my steering shaft to fit
By EastTNZ28 in forum General HelpReplies: 2Last Post: 09-23-2007, 11:09 AM -
WTB: LS1 steering shaft linkage
By always faster in forum Parts Wanted / TradeReplies: 2Last Post: 06-02-2007, 07:45 AM
