Results 1 to 20 of 25
Thread: mysterious hose
    Member slpdablueZ28's Avatar
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    mysterious hose
    This morning I walk up to my car and see a black hose about half an inch thick hanging under my car roughly in the location of the cats. It looked like it had been cut. No fluids leaking and ses light. Take it to a mechanic he takes a looks at it says its something to do with the vacuum system and says its not needed and yanked it out. He said he suspected the engine had been changed or something but I doubt that. Should I be worried about anthing
    2002 z28-slp cai, slp loudmouth, slp tuned headers, slp 85 mm MAF, slp high flow cats, 3" y-pipe and collectors
    331.6 rwhp/356.9 rwtq
    Bragg NC
    Met. Sunset Orange
    01 SS
    Got pics? Was it connected to anything or just wedge in there?
    J
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    Was it on the driver's side? Could be the outer sheathing from the line that connects the clutch master and slave. If they were to have cut the end off the line and just yanked it up the sheathing would have stayed wedged under the heat shield. I'm just guessing but that's the only rubber line I can think of that runs down by the cats.
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    No pics but it went up and above the transmission then forward. It was a rubber hose about 2 feet long. I think he might have said something about the VAT system but I don't know anything about that
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    And I didn't see the other end of it after the cut
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Maybe it was the auto transmission vent hose?
    ^^ I was thinking the same thing. From the factory, it is clipped to the front of the torque arm. If anything has been changed it is likely that it was re-routed and may have simply come undone.
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    so theres nothing to really worry about?
    Madison, WI
    2001 Silverado Z71
    You should be ok
    Member crossbredfoxbody's Avatar
    First In Flight
    83 mustang coupe
    How big around was the hose?
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    not too big like i said maybe about a 1/2 inch diameter or 3/8 the rubber was pretty thick
    First In Flight
    83 mustang coupe
    Trans vent is not that big, The trans hose is like 1/4 or 3/16
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    yeah i have no clue wat it might be, but the car runs fine
    Madison, WI
    2001 Silverado Z71
    Quote Originally Posted by crossbredfoxbody View Post
    nope...its about 3/8 to 1/2 inch OD, maybe even a tad bigger. I think we have this mystery figured out.
    First In Flight
    83 mustang coupe
    Are we talking about a auto or manual trans vent?
    First In Flight
    83 mustang coupe
    Ive never seen a auto that big. I thought he had a automatic
    I'm in the middle of an axle swap on my car, so here's a pic of the transmission vent hose hanging down. Again, this would normally be clipped to the top of the torque arm.
    First In Flight
    83 mustang coupe
    Thats not 3/8 or 1/2 is it its smaller!!!
    Tough crowd... tough crowd. Ok, I went back out to the garage and measured it. The hose is marked 3/16" and has an outside diameter of 3/8".
    First In Flight
    83 mustang coupe
    We was on 2 different pages I was on advertised size which is inside diameter sorry man.
  1. Mysterious object found in the Baltic Sea
    By SiggyZ in forum Almost Anything Goes
    Last Post: 02-02-2012, 12:01 PM
  2. Mysterious Missile Lights Up Sky
    Last Post: 11-11-2010, 07:27 PM
  3. Help: mysterious light?!
    By 99TransAmSLP in forum General Help
    Last Post: 09-17-2009, 01:23 PM
  4. mysterious white Z in the neighborhood
    By myk02k in forum Almost Anything Goes
    Last Post: 07-14-2006, 11:11 PM
  5. The Mysterious LS1 tapping solved!!!!!!
    By CamaroCrazyChris in forum General Help
    Last Post: 11-05-2005, 06:13 AM
