02-17-2006, 09:11 PM #1
? about my ss hood/cold air intake....
ok so my z28 is in the shop gettin the ss hood put on and it is a functional hood, i also have lying around the SLP cold air intake, the one that draws air from underneath....? is, would that have any effect since i got the funtional ram air now with the hood, or would adding the SLP one just be a lost cause????
02-18-2006, 06:47 AM #2Member
- Jan 2006
- maine
silver- 2002 z-28
more air the better
02-18-2006, 07:07 AM #3Senior Member
- Little Rock, Arkansas
- 1966 Corvette Coupe
from what i have read its not always more is better... the air comming together in the air box actually causes turbulence which is not good... most ppl on here will recommend one or the other... not both...
if you look through here i think this is a question that is ask pretty frequently so there should be quite a bit of info on it
-Me
02-18-2006, 07:33 AM #4Member
- Jan 2006
- maine
silver- 2002 z-28
keep readin then....cause the ss hood realy doesent even work until you reach higher speeds....like say over 120 mph........the slp cold air kit which i have on my car is just the opposite. so unless he does all his driving at daytona....the SS hood is pretty much just for looks
02-18-2006, 08:55 AM #5Senior Member
well there is your answer... ill have to pull the "im used to pontiac" card on that one...
-Me
02-18-2006, 12:47 PM #6
ok thanks guys, ill prolly just put the dang thingon then.....thanks for the help.....
02-23-2006, 04:32 AM #7I went to Playboy Mansion
- Sep 2005
- Bakersfield/Long Beach Ca
YJ- 04 GTO M6
You can always do the FRA mod to help your car breath a bit better.
What Lid/Cold Air Intake?
By WS6Dream in forum External EngineReplies: 19Last Post: 04-20-2011, 04:27 PM -
Want: LT1 Cold Air Intake
By Zapper2003 in forum Parts Wanted / TradeReplies: 0Last Post: 03-04-2008, 03:57 PM -
which cold intake?
By aluna in forum External EngineReplies: 2Last Post: 03-03-2008, 05:49 AM -
Slp Cold Air Intake
By RYDER661 in forum General HelpReplies: 3Last Post: 04-03-2006, 09:25 PM -
Cold Air Intake
By Clint Eastwood in forum LT1Replies: 10Last Post: 08-06-2005, 09:30 AM
