Results 1 to 3 of 3
Thread: msd opti timing screw
01-08-2010, 01:21 PM #1
the manual on the msd opti doesnt say how the timing screw adjusts the timing, just that it does so +/-7 degrees and that stock is two turns out from all the way in. so to advance/retard, is it screw in to advance, or does that retard etc. anyone know off hand?
ps it also says that the 96-97 lt1 being obd2 change timing at idle, and so to set the advance when about 1500rpm or so... does that mean someone should hold the rpm at 1500 while doing the adjustments, or to adjust with the screw until that rpm is reached at idle?
01-08-2010, 01:35 PM #2
nevermind found it here
http://www.msdignition.com/forum/showthread.php?t=11804
01-08-2010, 02:00 PM #3Senior Member
- Feb 2006
- Orange County, NY
It sounds like you want to do it with someone holding it at 1500. Is there even a mark to see what the timing is?
opti and timing help
By 383lt1ta in forum LT1Replies: 1Last Post: 09-12-2010, 02:46 PM -
How bad did I screw up?
By Spikito in forum Gun's & AmmoReplies: 6Last Post: 01-04-2010, 10:15 AM -
Question: Did I screw this up??
By SMWS6TA in forum Manual TransmissionReplies: 8Last Post: 07-04-2009, 11:29 AM -
Ls1 timing cover, Dual row timing chain
By xssive in forum Parts For Sale / TradeReplies: 0Last Post: 08-06-2007, 06:41 PM -
How to screw up a third gen...
By 86 IROC-Z in forum Almost Anything GoesReplies: 9Last Post: 04-27-2006, 03:05 PM
