    Member Larry's Avatar
    Sugar Land, Texas
    2017 Z06
    Tire diameter vs. speedometer question
    In HP Tuner if you increase your tire diameter does your speedometer slow or go faster? I used to know but if I remember right the logic is opposite from how it actually changes.
    NeW YoRk
    2001 ws6
    not sure but thinking about it logically, if you get bigger rims the car is going to read its going slower than it actually is.......but thats just my opinion, subscribing to learn something as well
    Member Benner's Avatar
    Delaware, OH
    2001 GrandPrix GTP
    Larger diameter means you'll actually be going faster than what your speedometer show. I.E. (when your speedo says 60 you're actually going 65)
    Agree. Each full rotation of a larger tire travels a greater distance than a smaller tire.
    Sugar Land, Texas
    2017 Z06
    Quote Originally Posted by Benner View Post
    True in real life but not sure that is the way HP Tuner recognizes tire diameter in their program or should I say GM's PCM.
    NeW YoRk
    2001 ws6
    i was right!
    "The Snake Skinner" Smokaholik's Avatar
    Oklahoma
    2001 WS-6 M6
    so how do i correct my speedo for the larger diameter?
    Quote Originally Posted by Smokaholik View Post
    You reprogram the PCM -- can be perfromed with a handheld or any of the commercially available tuning programs. You can also obtain a mail order tune from Frost (site sponsor) in which this can be accomplished along with his other performance enhancing tweaks.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
  1. Tire diameter difference
    By pajeff02 in forum Wheels and Tires
    Last Post: 08-28-2010, 10:17 PM
  2. Question: Tire Diameter ? everyone plz chime in
    By Smokaholik in forum Wheels and Tires
    Last Post: 01-18-2010, 03:02 PM
  3. Tire Diameter And Abs???
    By EXTNCT in forum Wheels and Tires
    Last Post: 08-15-2007, 07:04 PM
  4. How will tire diameter affect gear ratio???
    By 98ls1blackbird in forum Automatic Transmission
    Last Post: 04-06-2006, 06:30 PM
  5. Wheel diameter question
    By 91Z28 in forum Wheels and Tires
    Last Post: 10-07-2005, 05:56 AM
