Results 1 to 18 of 18
    middle aged teenager WS6S's Avatar
    Nov 2009
    lawrenceville georgia
    sunset orange/ black
    two 2001 ws6 m6
    clutch master r&r
    any tips on swappin out the clutch master,i cant even see where the hell it is to get it in and out,removed the 2 bolts under the dash,wtf is next.2001 ws6
    Nov 2009
    two 2001 ws6 m6
    clutch master R & R
    dash out 2 bolts removed,clip off linkage.now how the hell do you get the master cylinder out from behind the brake booster and how do you disconnect the braided line to the slave.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Its below the brake booster. Don't worry about trying to see it because you can't. you'll have to do it all by feel. Also a second person is nice to have so they can hold the master in place while you start the nuts.
    Nov 2009
    two 2001 ws6 m6
    10-4 thanks
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Nov 2009
    two 2001 ws6 m6
    i cant even get the fucker out.waaaaaaaaaahhhhhhhhhhh !!!
    Nov 2009
    two 2001 ws6 m6
    ya i used that but i still cant get the thing out of there.the main wiring harness is stopping it from coming all the way out.
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    Quote Originally Posted by WS6S View Post
    I took the booster off of mine.
    Nov 2009
    two 2001 ws6 m6
    finally got it off and out,now i cant get it to bench bleed,tomorrows another day.
    Madison, WI
    2001 Silverado Z71
    Nov 2009
    two 2001 ws6 m6
    dont have a bleeder,i did try using my shop vac and pulling vac threw the slave side but no good,off to my buddys tranny shop to use his mighty vac or whatever he has.
    Nov 2009
    two 2001 ws6 m6
    got it bled finally but somebody better call the wammmbulllance cause its not wanting to go back in its home.ive walked away 3 times so i dont break anything,i wouldnt wish this job on my worst enemy.i would rather put a clutch in a peterbilt b4 ever doing this again.waaahhhhhhhhhh !!!
    Madison, WI
    2001 Silverado Z71
    Are you saying you can't get the hose to reconnect to the slave? If there is pressure in the hose or slave, it won't slide back on easily. I read about this many times. I think the answer is to open the slave bleeder then try to push the hose on
    Nov 2009
    two 2001 ws6 m6
    nope just the whole assembely would not line up ,i finally just removed the booster and had plenty of room to get it in.i just cant believe what a hard time it gave me,the slave had to be cracked to releave the pressure to get the master cylinder hose on.next time i do a clutch master will be much easier as i will remove the brake booster to gain access.im just so happy its done.tomorrow im throwin in some 4.10,s and should be a pleasure compared to this job.
    Nov 2009
    two 2001 ws6 m6
    Quote Originally Posted by Goldcuffs View Post
    that was the ticket brother,thanks
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    When I put the Tick Master Cyl in mine, I ended up dropping the steering column- real easy to do only a few bolts and it made getting the old one out real easy and putting the Tick in a breeze (which is a pain no matter how you look at it because it has a huge mounting plate!).
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    If you remove the booster it will make life a lot easier! (I reallized after I did mine)
    I had my niece help me put mine in, she had smaller hands. Also I drilled out the holes a little bigger to make it easier for the bolts to slide in.
  1. Question: clutch master
    By 01ssus11retread in forum Manual Transmission
    Last Post: 09-23-2013, 05:38 PM
  2. Question: clutch master??
    By JDCAMARO99 in forum Manual Transmission
    Last Post: 09-21-2009, 04:23 PM
  3. Replies: 21
    Last Post: 12-13-2007, 07:41 PM
  4. Clutch Master Help
    By Frozen WS6 in forum Manual Transmission
    Last Post: 06-24-2007, 08:41 AM
  5. Do I have a bad Clutch Master
    By phoenix1987 in forum Manual Transmission
    Last Post: 05-20-2007, 02:31 PM
