Results 1 to 10 of 10
    Member F-my-body's Avatar
    Oct 2009
    Midlothian Virginia
    2002 Z28
    i dont want a sub but i want more bass!
    i have a pretty cool system now and im really happy with it but i wish i could just get a liiiittle more base out of it and itd be perfect.i can turn the volume up to 16 with base on the highest setting but when i turn t 17 it sounds like its making an odd noise and then on 18 it makes that noise were it sounds like its kidna shasking lose or somthing but i heard if i play it to high like that it will blow so would i need better speakers or can somthing squeze more power out of it?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Do you have a stock head unit or aftermarket head unit? What speakers do you have?
    FYI - It is bass, not base.
    Member Benner's Avatar
    Delaware, OH
    2001 GrandPrix GTP
    all your base are belong to us
    Oct 2009
    Midlothian Virginia
    2002 Z28
    i do have an aftermarket head unit and im actually not quite sure ill check tomorrow tho
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Upgrading your speakers will have a very noticable difference.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    A speaker upgrade would help. If you have the monsoon system run new speaker wire to bypass the amp. You will also have more choices for speakers.
    Member Adam_94_T/A's Avatar
    Oct 2009
    North Carolina
    1994 Pontiac T/A
    You can run a aftermarket amplifier Memphis or Boston acoustics and running new wire also aftermarket head unit will make a big difference.
    Quote Originally Posted by F-my-body View Post
    16 to you might be 30 to someone else's so that's all relative. Are you distoring your speakers @ 1/4 volume? 1/2? 3/4? full? volume?
    If you're distorting at lower volume, you've got faulty wiring (i'm guessing a poor instal). If you're distorting at higher volume, you just want new speakers. You'll want 6.75" (aka, oversized 6.5") mid bass 2ohm drivers. A lot of people like the Elemenatal Designs e3.6, it's cheap and punchy. Crutchfield has a Kicker CompVT 08CVT654 and a JL Audio 6W3v3-4. (which you'll need to figure out proper wireing as they a 4Ohm)
    Distorting at a high volume could also be the result of your CD player and not the speakers as well. Having excellent speakers with a shitty amplifier will do you no good.
    Without an external amplifier, the best RMS wattage you are probably getting from your CD player is about 25-30 watts per channel with maybe a peak rating of 45 watts.
    If you try cranking it up beyond the RMS level, it will sound like shit no matter what speaker you get.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
  1. WTB 98-02 LS1 Air Filter Base
    By rodent in forum Parts Wanted / Trade
    Last Post: 11-11-2010, 03:36 AM
  2. kinda off base but help
    By heath26 in forum General Help
    Last Post: 09-14-2010, 06:35 PM
  3. Anyone ever Base Jump
    Last Post: 01-11-2009, 02:43 PM
  4. Base firebirds are v6 only!
    By allbaugh_04 in forum Firebird / WS6
    Last Post: 08-15-2007, 01:45 PM
