Thread: mirrors?
01-04-2010, 04:45 PM #1Junior Member
- Aug 2009
- Dover Plains, NY
silver- 1999 Z-28 camaro
mirrors?
why do some Z's and SS' have black painted side view mirrors. My 99 Z has them, and they make me sick. Also, what kind of paint can I use to shoot the berger panel matte Black?
01-04-2010, 04:51 PM #2Just me
- Nov 2006
- Broken Arrow, OK
The 98 and 99 models had the black mirrors from the factory. In 2000 they started matching the mirrors to the rest of the paint.
Any flat black rattle can will do the job, just do it properly.
01-04-2010, 04:59 PM #3Junior Member
- Aug 2009
- Dover Plains, NY
ok thanks, I didn't want to use dupli-color or something, then have it flake off in a month. I guess cuff up the silver with a brillo or something first?
01-04-2010, 05:02 PM #4
01-04-2010, 06:32 PM #5
+1. You should probably use a wax and grease remover first. If nothing else, at least wipe it down with some denatured alcohol or something similar. Then use a scotch pad, see example: http://solutions.3m.com/wps/portal/3...ives/Hand-Pad/ or wet sand it with 400 grit paper until the surface is completely dull. Blow or wipe off the sanding residue, or use a tack cloth, then prime and paint using light even coats.
01-04-2010, 11:58 PM #6
It should be inexpensive to get the mirrors painted from a body shop. As for the rear panel - as stated above, light sand with 400 grit, clean it well with a tack cloth, prime and paint.
01-06-2010, 06:39 PM #7
My friend had his mirrors painted to match his car at a body shop for $60.
As for the rear tail light panel, it is an easy project to do yourself, if you don't mind taking the time to do it properly. I'm sure it wouldn't cost much to have a body shop paint it if you took it to them.
Underhood Mirrors
By ls1camino in forum Appearance SectionReplies: 45Last Post: 05-09-2008, 05:22 PM -
Corvette Mirrors!?!
By T/A36 in forum Appearance SectionReplies: 17Last Post: 10-21-2007, 08:17 AM -
WTB -Outside mirrors for 98 Firebird
By waynet in forum Parts Wanted / TradeReplies: 5Last Post: 05-09-2007, 03:00 PM -
Under hood mirrors
By Rare99Firehawk in forum Showcar and DetailingReplies: 9Last Post: 04-15-2007, 05:18 PM -
Looking for mirrors
By enjun in forum Parts Wanted / TradeReplies: 3Last Post: 01-19-2007, 03:34 PM
