Results 1 to 13 of 13
Thread: Front Turn Signal
01-01-2010, 09:29 AM #1Member
- Nov 2009
- North Carolina
Black- 2001 Camaro Z28
Front Turn Signal
Im trying to remove the front turn signal assembly in my 2001 I jacked it up and got everything loose the whole assembly is free but i cant get it out! Does anyone know if you have to remove the headlights and pull them out throuhg the top?
01-01-2010, 10:59 AM #2
it comes out through the bottom. remove the flap that always hit the curb when you park in a lot (its like 12 bolts if i remember right).
01-01-2010, 11:16 AM #3Member
- Nov 2009
- North Carolina
01-01-2010, 11:28 AM #4
I just removed the two 10mm bolts for the flap and then had to find some tiny sockets to remove the several bolts if I remember correctly. It came right out (two years ago). I remember It was hard to get a ratchet to fit in the space for all of them.
01-01-2010, 11:48 AM #5Member
- Nov 2009
- North Carolina
01-01-2010, 11:53 AM #6Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
01-01-2010, 11:55 AM #7
I honestly can't remember how I removed mine. Walked into the garage and popped the lights. It looks like there's a backing plate which they are bolted to. I would try to pop the headlights, then turn them to the middle setting to turn off the bulbs. You should be able to see and move the drl around from above. I don't think I slid it outwards from the bumper, but positive it won't go back.
01-01-2010, 12:11 PM #8Member
- Nov 2008
- harrisburg pa.
they can't come out the front, the lens is bigger than the hole in the bumper. if i remember right there's only 2 bolts holding the whole headlight assembly. unplug, unbolt and get it out of the way.
01-01-2010, 03:54 PM #9Member
- Nov 2009
- North Carolina
so the corner of the signal is hitting a bracket on the inside of the car and it looks like the headlights are coming out now
01-02-2010, 09:10 AM #10Four Seat Vette
- Oct 2009
- pasadena md
- Blog Entries
- 2
Black- 2002 SS Camaro
i had a real hard time with mine as well i took it out the top after i took my headlights off
01-02-2010, 09:27 AM #11Member
- Nov 2008
- harrisburg pa.
i don't know. maybe taking the headlights out would help.
01-02-2010, 02:44 PM #12Member
- Nov 2009
- North Carolina
01-02-2010, 03:21 PM #13Member
- Nov 2008
- harrisburg pa.
another front turn signal problem
By hiredgun58 in forum Firebird / WS6Replies: 3Last Post: 03-28-2015, 01:29 PM -
Help: ws6 front turn signal screws
By james3340 in forum Firebird / WS6Replies: 1Last Post: 06-09-2013, 10:11 AM -
I need a front right turn signal cover
By mcbeejw in forum Parts Wanted / TradeReplies: 0Last Post: 11-09-2006, 09:27 PM -
WTB: Front Turn Signal Pigtails for 98-02
By FormulaFiend in forum Parts Wanted / TradeReplies: 0Last Post: 10-19-2006, 05:44 AM -
Replacing L front turn signal bulb
By Danger731 in forum General HelpReplies: 6Last Post: 10-19-2005, 11:25 AM
