Results 1 to 11 of 11
Thread: clutch question
12-31-2009, 08:52 AM #1middle aged teenager
- Nov 2009
- lawrenceville georgia
sunset orange/ black- two 2001 ws6 m6
clutch question
01 ws6,exhaust,intake upgrades.the clutch slave is leaking in the car a little, high high pedal release point and chatters and slips a little but once it slips that little bit its fine.do i replace the slave cylinder/resevoir with a stock unit or adjustable unit.would my pedal be high because of the little leak.should i replace the clutch what should i do help ! oh ya i was told its a spec 3 clutch that hasnt been in the car for to long ?
12-31-2009, 01:29 PM #2middle aged teenager
- Nov 2009
anyone ?
12-31-2009, 01:40 PM #3
Take a read through this thread -- addresses Spec chatter: http://www.ls1.com/forums/showthread...t=clutch+slave
01-03-2010, 06:59 PM #4
You mean the master is leaking in the car?? The Master cylinder is the one that attaches to the back of the clutch pedal, the slave cylinder is the one in the transmission. If it is leaking, it needs to be replaced.
High release point means something is wrong, because hydraulic clutches are basically self adjusting. Clutch slip and chatter are definitely bad, but I'm not surprised to hear that if it is in fact a Spec 3 clutch. And yes, a badly worn clutch disc or defective hydraulics can cause the clutch pedal to engage at a higher point.high high pedal release point and chatters and slips a little but once it slips that little bit its fine.do i replace the slave cylinder/resevoir with a stock unit or adjustable unit.would my pedal be high because of the little leak.should i replace the clutch what should i do help ! oh ya i was told its a spec 3 clutch that hasnt been in the car for to long ?
01-04-2010, 07:06 AM #5middle aged teenager
- Nov 2009
ya i thought that she needed a clutch when i test drove her.so now monster clutch stage 1 or ls7 or stock ? and tick master or stock.
01-04-2010, 12:59 PM #6
What are you planning on doing with the car?? Its its a street driven car with bolt ons that only sees the track a couple times a year, the LS7 is the perfect choice. If you have more than just bolt ons, or you go to the track regularly, then go with a Monster clutch.
As for the master cylinder, I would just go with the stock GM one, they work just fine.
01-05-2010, 10:52 AM #7middle aged teenager
- Nov 2009
you know what wesman i am gonna go with the ls7 and stock master,thanks.,.
01-05-2010, 02:15 PM #8
Are the Specs known for being weak clutches?
01-06-2010, 08:21 PM #91998 Trans Am WS6 SGM
Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
01-06-2010, 08:23 PM #10
Do it once, do it right.
GM Replacement Master Cylinder & LS6-LS7 Clutch.
.....just my .02
01-10-2010, 02:36 PM #11
Help: clutch question?
By BADHAWK209 in forum Manual TransmissionReplies: 1Last Post: 01-12-2011, 08:11 PM -
Clutch question
By Badazz Z28 in forum Manual TransmissionReplies: 2Last Post: 01-04-2011, 02:17 PM -
Clutch question
By buzzkill in forum Manual TransmissionReplies: 2Last Post: 06-16-2009, 07:10 PM -
LS7 Clutch Question
By 2000sscamaro in forum Manual TransmissionReplies: 1Last Post: 03-27-2007, 06:21 PM -
clutch question
By 98silveraptorhoodws7 in forum Western MembersReplies: 6Last Post: 10-14-2006, 05:06 PM
