    Parma Heights, Ohio
    SOM
    99 Trans Am
    turn a y pipe into a true dual system
    Ive been thinking about getting rid of my mid length headers for a LT setup with true duals. A lot of true dual systems are pretty expensive and getting one made is also a lot of money so i got to thinking. Lets say you took a QTP y pipe(because it has a flowmaster merge) cut a couple inches off it and then took another flowmaster merge cut the exact same amount off of that one and then welded them together essentially creating an x pipe. from that point on you could either run it out the back or run a small pipe to a to small resonator and turndown before the axle, for those of us that want something loud.
    i was also thinking of just running a borla xr1 off the the end of the merge but i dont really want the exhaust to be restricted by coming down to one pipe so id wanna make the section off the merge as short/efficient as possible by probably just making the merge 4inches to the borla
    im just thinking out loud so this is some food for thought.
    Coral Springs, Fl
    Sunset Orange Metalic
    In theory your idea should work, but i think you'd be better off with a custom setup. You can buy a universal x-pipe kit off of summit and have an exhaust shop fit it to your car for much cheaper than modifying a QTP ypipe
    Parma Heights, Ohio
    SOM
    99 Trans Am
    you think so if i supplied my own xpipe? i know the QTP y pipe is expensive but if i was to go that i way i wouldnt buy a QTP, there are a couple others out there.
    Coral Springs, Fl
    Thats what i was gonna do, just supply my own parts (x-pipe, mufflers, tips)
    Just pay the labor to have it fabbed up
    Member JRENIGAR's Avatar
    Oct 2009
    arkansas
    99 camaro
    OP has a good idea to me, I was thinking about the same thing when I do my headers this spring. I think the purpose of the tsp pipe is for mandrel bends. If you were to rotate the 2nd merge a lil you could probably stagger the pipe outlets to run down the trans tunnel without bending any pipe till after the bullet mufflers. Then just get some turndowns and have a complete mandrel bent dual exhaust for around 500 or so in change. Just a thought though....
  1. LPP True Dual System
    By Last of the Breed in forum Firebird / WS6
    Last Post: 10-07-2010, 01:19 PM
  2. summit x-pipe true dual
    By fastlt196 in forum External Engine
    Last Post: 03-31-2010, 04:39 AM
  3. Where to buy True Dual w/X Pipe
    By ChrisV 02 - Z28 in forum External Engine
    Last Post: 01-04-2008, 04:03 AM
  4. Which True Dual System?
    By bgable in forum External Engine
    Last Post: 09-01-2007, 07:11 AM
  5. Replies: 9
    Last Post: 06-29-2006, 01:56 PM
