Thread: Driving light change
12-23-2009, 08:25 AM #1Junior Member
- May 2009
- Southern Illinois
Midnight Blue- 01 TA WS-6 Conv
Can someone tell me the way to change the bulbs on my driving lights on my 01 TA. I don't see a way to get to the back of the lens without alot of disassembly. I don't mind taking it apart but I figured there would be a quicker way. Thanks.
12-23-2009, 09:00 AM #2
Define driving lights first of all, but if you are talking the turn signals in the front facia, easy to do, either reach through the openings below or use the trap door under the front, you will need to get right on the ground to see them.
For the fog lights I just reach through the top and contort my hand a bit to get to them, I think you can also get them from underneth as well.
12-23-2009, 11:34 AM #3Junior Member
- May 2009
- Southern Illinois
Yea the fog lights. I don't see a way to get my arm down far enough to reach them. Might give it a shot though.
12-23-2009, 12:53 PM #4Senior Member
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
lift up your headlights manually, your owners manual can tell you how, then take off th black plastic cover around the lights, you now have easy accress to the back of the DRLs
12-23-2009, 04:06 PM #5Mustang killer
- Aug 2009
- Florida
White/ Blue stripes- 1999 30th anniversary
12-23-2009, 11:24 PM #6
I pulled the clips out of the bottom of the bumper and squeezed behind it to get to the fog lights. You'll have to do it mostly by feel, but I couldn't wedge my arms in from the top either.
12-24-2009, 08:32 AM #7
Why the hell did they design it so you can't change out a bulb simply? It's a real PITA, I have to go up from the bottom of the bumper. I mounted them closer with aftermarkets so theyre easier to change out
12-24-2009, 03:23 PM #8Junior Member
- May 2009
- Southern Illinois
Thanks Guys. I'll go and give it a shot.
12-27-2009, 11:36 AM #9Army Dude
- Nov 2007
- Ft. Rucker Area, Lower AL
Arctic White- 01 TA / 06 Duc 749D
Get a 10mm wrench or socket and remove the front two bolts from the plastic slashgaurd underneath the DRL's. After that you can move and access panel down and reach up from underneath and undo the light socket to change bulbs. Or if your hands are not to big you can reach in from the useless opening directly underneath the DRL and reach it from there.
Driving light
By Butch2000 in forum Parts Wanted / TradeReplies: 0Last Post: 04-07-2010, 02:12 PM -
Security light comes on while driving??
By 98T/ACOBRAEATER in forum General HelpReplies: 10Last Post: 10-09-2009, 08:38 AM -
How to change a tire while driving...
By suede in forum Almost Anything GoesReplies: 8Last Post: 11-13-2008, 07:35 PM -
driving light lens
By kool4all in forum GTOReplies: 3Last Post: 05-27-2008, 03:18 PM -
Driving Light Question
By enjun in forum Camaro / SSReplies: 2Last Post: 03-02-2007, 04:50 PM
