Results 1 to 3 of 3
12-22-2009, 01:34 PM #1Member
- Oct 2005
- Lincoln, CA
Pewter- 2000 Z28 Camaro
2000 Z28 w/short in radio/pwr window circuit
My 00 Z28 has the deluxe Bose package. Lately, when I start the car up cold (I'm in the S.F. Bay Area, so "cold" is a relative term) the radio will come on and then just shut down. It goes black and will not respond to the on/off switch. If I hit a bump it will come back on. No resetting of time or stations required. It might shut back down a second or third time, but eventually stays on. When the radio is down I noticed that my power windows also don't work. I assume they are on the same circuit. BTW, this is a very intermittant problem. It only happens once in a while. I probably couldn't demonstrate it to a mechanic or electrical guy. Once the car is warmed up the radio (and windows) work just fine. This leads me to assume that the problem is related to a cracked solder joint. When the joint warms up it expands and the short goes away. Does anyone know what other systems might be on this circuit? I could confirm the circuit problem if I had another item to check besides the windows. Anyone have any idea what the problem might be, or have you experienced this before?
12-22-2009, 02:02 PM #2Senior Member
- Feb 2006
- Orange County, NY
Many people have this problem. It is usually a bad solder joint in the bcm. It is located near the glove box. Here is a thread with some info. http://ls1.com/forums/showthread.php...ght=bcm+solder
12-23-2009, 09:32 AM #3Member
- Oct 2005
- Lincoln, CA
Thanks for the lead. I probably should have conducted a search before asking my question.
Help: radio and window problem
By TransAmFanatic in forum General HelpReplies: 6Last Post: 08-01-2011, 04:58 PM -
radio electrical short......?
By ss#2420 in forum Stereo and ElectronicsReplies: 4Last Post: 07-16-2010, 11:07 AM -
power window and radio shortage
By ss2000 in forum General HelpReplies: 17Last Post: 03-18-2010, 02:23 AM -
Help: radio and window cahoots!!
By MSTrespctDAmuscle03 in forum General HelpReplies: 4Last Post: 08-31-2009, 07:12 AM -
short in fuel pump circuit
By TryMe in forum General HelpReplies: 0Last Post: 07-09-2009, 06:58 PM
