Thread: Good combo?
02-16-2006, 10:21 AM #1waldo31031Guest
Good combo?
Lunati Hydraulic Roller Camshaft
Comp Cams Hydraulic Roller Lifters
Dart Speed Flow Cylinder Heads, Pair
BBK High Flow Throttle Body
Holley Intake Manifold
Do ya'll think this is a good combo?
02-16-2006, 10:39 AM #2waldo31031Guest
do i need anything else? my car has 100k on it. It is a 00' ss A4. I am going to get a 3500 stall. If there is anything else that i need please let me know.
thanks
02-17-2006, 05:11 PM #3
- Dec 2002
- n/w chicago
whats the cam specs and what version of dart heads??
you gonna have the heads milled or ported?
youll need a whole cam kit that has springs and all.
also hardened pushrods, high flow oil pump and ls2 timing chain.
save youre money and port the stock throttle body and get a used or new ls6 intake.
a 3500 stall is good, get a shift kit and a trans oil cooler for it also.
a dyno tune will also be needed for everything to run good.2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
02-19-2006, 04:10 PM #402TransAm/BatmobileGuest
here's what you should aim for, . .
mild to big cam, something in the 230's with new springs and pushrods, ls2 timing chain is not necessary, oil pump is not necessary either, just port your current oil pump, . . the BBK throttle body is 80mm while the stock one is 78mm, . . jus port the throttle body, waste of a few hundred with the BBK, why the holley intake? i think the only advantage towards the holley is that its designed for a hassle-free direct Nitrous injection. . . . . i would get an ls6 intake, . . or better yet, . . get the new 90mm ls6 intake from TPIS followed witha NW throttle body, . . . . but before you go through all that performance take care of the foundation, . . .
02-19-2006, 04:14 PM #502TransAm/BatmobileGuest
oh, i forgot about the heads, . . im currently shoppin for some heads too and im leaning towards the CNC machined LS6 heads, . . the 5.3L heads have a smaller combustion chamber but also smaller valves, . . you would have to buy new and bigger valve seats and valves, . . i dunno, the LS6 heads seem to be a better bang for the buck, . . but like i said . im still shoppin, . . . and what about your exhaust? you can't jus eat and eat and eat and not poo could you? you need to let your ss breathe towards the back end
02-21-2006, 05:41 AM #6waldo31031Guest
i have full Borla and long tubes already. Also, I have a 00'. I thought the stock TB and intake manifold was like between 55-60mm?
02-22-2006, 02:15 AM #7
12 bolt..........you are gonna need it sooner rather than later
02-23-2006, 07:43 AM #8waldo31031Guest
thought so... Around how much hp will the stock rear end hold?
02-23-2006, 09:57 PM #9
Originally Posted by waldo31031
Question: Is this a good combo
By karpetcm in forum Suspension and HandlingReplies: 1Last Post: 10-22-2009, 11:20 AM -
Good combo?
By garver in forum Internal EngineReplies: 3Last Post: 04-17-2008, 08:13 PM -
Good combo or 99-02 LS1??
By shaggsm3ls1 in forum Internal EngineReplies: 22Last Post: 02-04-2008, 01:37 PM -
Is this good combo?
By imflyn in forum Stereo and ElectronicsReplies: 3Last Post: 11-15-2006, 08:01 PM -
is this a good combo?
By third_shift|studios in forum Suspension and HandlingReplies: 4Last Post: 06-13-2006, 02:47 PM
